Old 03-29-2010, 12:25 AM   #1
Exclamation Lack of Wheel Well?
I have recently purchased a 2010 Salem 26TBUD. I had it shipped 2500 miles to my home destination. Along the way, snow, mountain passes ect, the wheel has rubbed and tore through the black under skirting. After investigating I've found that the insulation under the slide out is packed out causing the clearance of the wheel to be 3/4 of an inch. Now I have an area that is torn and full of road grime that will not dry. My last R-vision travel trailer had metal wheel wells. How do you fix this membrane? Is this the way they are building these trailers now, or is mine missing something?
ID:	2346   Click image for larger version
ID:	2347   Click image for larger version
Canadian True North is offline   Reply With Quote
Old 03-29-2010, 01:44 AM   #2
I would say you have a design issue with this trailer. The axle manufacturers recommend a mininum 3 inch clearance.
I would contact customer service at the plant where your trailer was made and explain the problem to them. They should foot the bill to add spacers to raise the trailer up to minimum acceptable height. Not sure what to say about the damaged fabric, I would take it up with the factory.
John U
2007 Rockwood 8315SS
2014 Silverado 2500HD 6.0L
midnightpumpkin is offline   Reply With Quote
Old 03-29-2010, 06:56 AM   #3
Head Rambler
I agree with John. That's either a design issue or a construction issue. The mfg. should take care of it. I assume it has the artic package is why it has that much insulation but it still shouldn't be that close to the tires.
Gotta go campin!
Old 03-29-2010, 06:58 AM   #4
milzat's Avatar
I'd thrid what John said. Call your dealer.
milzat is offline   Reply With Quote
Old 03-29-2010, 09:50 AM   #5
Dave_Monica's Avatar
If that's not bad enough, it's rubbing when the trailer is empty...it will only be worse when you load with your gear!
There was a post a while back from another Salem owner with the same problem. TT Lift Kit?
It sure looks like a design problem! Surely Forest River will take care of it!
Dave
Old 03-30-2010, 12:53 AM   #6
I'll take your great advice guys and get a hold of the dealership that I bought it from, and see what they can do. Does the tarp bottom hold up after time? Should I have aftermarket wheel wells installed to be on the safe side?
