Old 03-14-2014, 05:13 AM   #1
rburns4147's Avatar
Landing Gear Question
We just picked up our Rockwood 8285IKWS yesterday and are excited about getting it ready for our first trip. This is our first fifth wheel, having upgraded from travel trailers. I guess my questions are basic so I apologize for that.
The first is about plastic leveling blocks. I have always used them on our TT to level the wheels and then for pads underneath the stabilizing jacks. Are they strong enough to put under the fifth wheel landing gear? It seems to me that there is a lot of weight on the landing gear.
The second question is about getting the landing gear even. If you get the wheels pretty level from side to side with blocks, then find that the ground under the landing gear is uneven, how concerned are you with getting both landing gears pads to hit the ground at the same time? I would think you could carry a 2 x 8 board that is 1.5 inches thick and another that is half that (like a deck board). Do you also need one that is half that too so that you can get really close?
Ron and Elizabeth
2014 Rockwood 8285-IKWS
2006 Ford F250 6.0 Diesel 4x4
rburns4147 is offline   Reply With Quote
Old 03-14-2014, 05:25 AM   #2
Witch Doctor's Avatar
Plastic blocks are strong enough and interlock not like wood, but not good during the winter. they will freeze into the ground.
Rockwood #8289 WS 2012
F250 6.0 / Husky 16k
With 4 point leveling system
Old 03-14-2014, 07:51 AM   #3
Fulltime family RVer
I generally prefer wood under my landing gear. Not sure why, though.
I also try to get my landing gear to make contact with the ground at as close to the same time as possible. I carry 4 or 5 pieces of 2 x 10 rough cut lumber and a piece of 1 x 8 for "fine tuning" the contact. The 2x10s are different thicknesses, so depending on my mood- I may try a thinner or thicker one.
Whatever you do, watch out for aliens:
Old 03-14-2014, 07:55 AM   #4
Some folks even cover the top & bottom of the plastic blocks with alum tread plate and bolt to the pads to keep them from breaking on gravel and sinking/freezing to the ground.
Old 03-14-2014, 08:34 AM   #5
TURBS's Avatar
Is your horn broke yet?
TURBS
Sabre owners united!
Old 03-14-2014, 08:41 AM   #6
Somewhat right of center
Crabbyguy's Avatar
I cut up some 2x10''x10ft PT wood into a bunch of 10x10s and stack them grain opposite to whatever height I need. Don't care much for plastic.
2014 Crusader 260RLD Champagne Touring Edition
2013 Silverado 2500 6.0 HD
Crabbyguy is offline   Reply With Quote
Old 03-14-2014, 08:54 AM   #7
BombDoc's Avatar
I got a PT 4"X6" from Lowe's and cut it down to about 13" and have one under each of the landing gear and the rear stabilizers. Works well. They just ride in the back of the truck just inside the tailgate so once I'm level side to side (I use the orange stackable blocks) I put one on the ground and disconnect 5'er from TV. The 4"X6" blocks work well in the sand. As far as both landing gear touching down at the exact same time, rarely does that happen. I haven't had a problem yet and I've seen the landing gear 2" off from one to the other.
John & April & "Scout"
2013 Sabre 32RCTS-6
Nights Camped 2013-(44) 2014-(59) 2015-(47)
2016-(32) 2017-(13) 2018-0
BombDoc is offline   Reply With Quote
Old 03-14-2014, 08:55 AM   #8
Dave_Monica's Avatar
You can set the landing gear legs different one side to the other...I think the hole spacing is about 1". I carry a 1/2" thick board if I need something between.
Dave
Old 03-14-2014, 10:03 AM   #9
TURBS
Not the only one that has them. na, na, na, na.
