Old 10-14-2016, 10:42 AM   #11
brookstone345sa's Avatar
I liked the new one much better, it has aluminum case. The original was plastic. It was easy install. Good luck
brookstone345sa is offline   Reply With Quote
Old 10-14-2016, 10:46 AM   #12
You are referring to the gearbox. This is about the gears. Yes, my original one was plastic and the new one I purchased from etrailer is aluminum that seemed better. If I had swapped out for the new already, I would have shipped my old components to him.
OKI Marine is offline   Reply With Quote
Old 10-14-2016, 11:18 AM   #13
Yes this isn't about the gear box mine is fine I have broken teeth on the bevel gears.. So I'm hoping the ones I ordered will work. I let you know how I come out.
coleru59 is offline   Reply With Quote
Old 10-14-2016, 11:27 AM   #14
The top gear I was able to make work. The bottom gear no such luck. The through hole diameter was to small. I couldn't find a replacement gear for that one. The new ones I had purchased I thought about having that hole burned bigger on an edm machine at a local tool and die shop. That added expense that was costly. I also considered new landing legs but didn't know which "capacity" to purchase. Everyone wanted to know what I had and I couldn't find markings to tell. Then I decided on purchasing the Bulldog dual motor legs (10,000 lbs.)
Old 10-14-2016, 11:50 AM   #15
Carbide bit (masonry) and a slow drill motor with coolant.
Old 10-14-2016, 12:41 PM   #16
AquaMan's Avatar
Doubt that the gears are that hard that you would have to EDM. Jig grind or mill would make easy work of it. A masonry bit wouldn't work, no cutting edge. If a person could take the proper measurements, pretty sure you could find a replacement. I've done it multiple times and replaced them with quality parts. If they're made in Dayton, I have a pretty good idea who makes the gears.
2016 Georgetown 364TS
Nights Camped
2014 - 56
2015 - 41
2016 - 81
Old 10-14-2016, 12:47 PM   #17
Originally Posted by AquaMan View Post
... A masonry bit wouldn't work, no cutting edge.
Masonry bits I buy have 2 carbide cutting blade inserts.
Old 10-14-2016, 12:59 PM   #18
Left Coast
Router bits also work...
Retired....but work part time as a pain in the north end of a south bound donkey.......2010 Rockwood 8280 5er....99 Dodge 2500 turbo Cummins
bob caldwell is online now   Reply With Quote
Old 10-14-2016, 12:59 PM   #19
AquaMan's Avatar
All the ones I've seen and used (family is in concrete business and I'm in tool & die) have carbide inserts, but won't cut through a piece of pine. They're made for hammerdrills.
Nights Camped
2014 - 56
2015 - 41
2016 - 81
Old 10-14-2016, 01:02 PM   #20
Left Coast
I'd test the hardness with a file..
