Old 05-06-2016, 09:58 PM   #1
Landing leg bevel gear rebuild kit
Recently started a post about my landing gear on my 5th wheel. I was thinking it was just the gear box and to those that responded to that, thank you. I had trouble tracking down the build ( components) of my camper. I stayed with the dealer only to be given a number to Forest River in Indiana. They gave me a number to a place in California. Once I got ahold of the person there, he gave me another number somewhere else. He did say my landing gear is lippert. I bought a new gear box and bevel gear rebuild kits for both legs. Got the parts today but the gears are different. The twelve tooth smaller gear doesn't have the snap ring groove around the base of the outer diameter to cover the pin and hold in place. The new bigger 16 tooth gear has a 1/2" diameter hole through the center but the old gear has a bigger through hole. Anyone know which manufacturer made these?
OKI Marine is offline   Reply With Quote
Old 10-14-2016, 09:20 AM   #2
Did you ever find the correct bevel gears for your leveler legs? I have the same one with a ring clip that holds the pin in ..
coleru59 is offline   Reply With Quote
Old 10-14-2016, 09:33 AM   #3
No. I gave up and purchased the Bulldog dual motor landing gear from Etrailer.com. Researching gave me a lot of insight and everyone that offered an opinion suggested that given the size of my 5th wheel, that I needed a dual motor system.
Old 10-14-2016, 09:39 AM   #4
AquaMan's Avatar
Are the gears stamped with any type of markings? Regardless of who builds the landing gear or assembles the gear boxes, chances are they don't machine the gears.
2016 Georgetown 364TS
Nights Camped
2014 - 56
2015 - 41
2016 - 81
Old 10-14-2016, 09:56 AM   #5
Mine didn't have anything stamped on them. Lippert told me that there should be something stamped on the landing leg casing as well. I could never find it. I looked at the cap as suggested by a few but could not find anything there as well. The gears that I purchased, I made work. It was a temporary fix as the landing gear struggled to lift the coach. I have yet to install the dual motor legs but will try to do it soon.
Old 10-14-2016, 10:23 AM   #6
I can't find any stampings anywhere to identify.. attached a pic of the bevel gear..
Old 10-14-2016, 10:25 AM   #7
brookstone345sa's Avatar
Don't know if it's the same as mine. I just replaced my landing gear box and it is Lippert, However it's actually made by Venture. I found my replacement on Amazon, around $40
brookstone345sa is offline   Reply With Quote
Old 10-14-2016, 10:29 AM   #8
Thanks Brookstone, I just ordered the one you are referring to hoping its right!
Old 10-14-2016, 10:30 AM   #9
Check the gear box right where motor attaches, That's where I found the Venture stamping
Old 10-14-2016, 10:32 AM   #10
That is how mine looked. I spoke to the people at Venture (here in Dayton, Ohio) but because I'm local they said I had to go through an RV dealer. I figured if the original equipment struggled and eventually failed then I didn't want to do the same thing. Besides, to much unnecessary time spent wasted looking for replacement parts. I plan on having my unit for a LONG time. So, an upgrade for me was the solution.
