Old 02-14-2011, 11:38 AM   #1
lci control panel doesn't work. help
Anyone have the same problem?
troy is offline   Reply With Quote
Old 02-14-2011, 12:14 PM   #2
It would help tremendously if you would post the year and model of the RV you have. Also be a little more detailed in your description of the problem. List anything you have checked. Did you buy the RV new or used? Has it ever worked? And spell out what you are calling the Lci control panel. We can all help you better with a few more details.
LadyWindrider
2012 Ford F250 ext. Cab 4x4
2002 Jeep Wrangler Sahara
2008 Work and Play 18LT
Old 02-14-2011, 12:47 PM   #3
Send a message via Skype™ to scubieman
Also post a picture if possible.
2009 Dodge Ram Mega Cab 2500 6.7 cummins
2011 Forest River Cherokee 28BHKS
scubieman is offline   Reply With Quote
Old 02-14-2011, 01:12 PM   #4
I have a 2005 Georgetown. The Lippert control panel on the dashboard for the hydraulic jacks has no power. I've checked the fuses and breakers, all okay. Lights won't come on so I assume there is no power at all.
Old 02-14-2011, 02:01 PM   #5
LCI Control Panel
Not familiar with Georgetown 2005 models but have
you check the fuses in the Battery Control Center ?
The BCC is generally located close to the coach batteries.
Gary
mbtelguy is offline   Reply With Quote
Old 02-14-2011, 02:25 PM   #6
CLASS "A" Senior Member
cfsoistman's Avatar
Check under the steps inside the coach. There is a resettable breaker for the slides and levelers in there. On a 2005 it may be a fuse though? House batteries ok? Turned back on? I won't tell you how I know this could be an issue but it involves a generator barely cranking after someone, that would be me, turned mine off then couldn't figure out why it wouldn't crank.
Brain Fart - What preceeds $**tty ideas!
2007 Georgetown 370TS
aka - RAYNMKR
Driver: Charlie
Navigator: Sheri
Old 02-14-2011, 07:47 PM   #7
LCI wiring schematic
Hopefully The following schematic will help you
fix/identify the problem. I cannot say for certain
that Georgetowns are wired this way, however
I would think FR would follow LCI requirements.
Name:	Wiring diagram LCI Pump copy.jpg
Old 02-15-2011, 08:26 AM   #8
I've checked the breakers & fuses including the one behind the control panel. All are okay. I have 12 volts to the hydraulic motor, but the lights on the control panel are off. Like there is no power getting to the dash. Tech support at LCI said the supression module may be out. I guess I'll replace it & see what happens. Thanks.
Old 02-15-2011, 08:57 AM   #9
BigDTx's Avatar
How much is this supression module? If it is expensive then I would try to pull the LCI panel myself and verify that you are getting 12 volts to the back of the unit and that you havea good ground from the LCI control panel.
"Tech support at LCI said the supression module may be out." I would verfiy the failure first and verify voltages and grounds before I did any SHOTGUN troubleshooting and fired a supression module at the failure.
can TECH support send you a pin out diagram of the supression module and the LCI panel?
If you are getting 12V to the LCI oanel and a good ground then replace the LCI panel, if you are not getting 12v to the LCI then go the supression module and check for voltage into and out of the module. I hate when people say maybe this will fix the problem?? and maybe it will not and you can not usually return electrical parts. then you are out the money and still have not fixed the problem.
BigDTx is offline   Reply With Quote
Old 02-15-2011, 10:03 AM   #10
cfsoistman's Avatar
Here are the reference information manuals etc for LCI levelers and Slideouts. Hopefully what you're looking for is covered in here.
Lippert Hydraulic Leveling Jacks-Slideouts..pdf
Lippert Hydraulic Slideout Operations Manual.pdf
Lippert Troubleshooting Tips.pdf
aka - RAYNMKR
Driver: Charlie
Navigator: Sheri
