Old 05-16-2011, 09:55 PM   #1
Adony's Avatar
Leaking Pipe Connection
This past weekend I used my outside shower on the trailer.. It appears as though it is the one thing I didn't winterize as the valve body was cracked. I removed the enclosure, and replaced the valve. I also notice that one of the nylon / plastic rear connectors, appeared to be cracked but was not leaking. I decided to replace both of them while I had the shower box out. I replaced both 90 degree connectors with identical new connectors. When I reconnected everything and turned the water on, there was a slow drip from the connector as shown in the picture. I know that these connectors are usually hand tight, but I even tightened them a little more and still drip..drip..drip.. The valve and connectors are new but still leak (drip..drip..drip..) This must be fixed before I reinstall the enclosure with butyl tape / screws. Any ideas what I might have done wrong or need to do??
Adony is offline   Reply With Quote
Old 05-16-2011, 10:18 PM   #2
Send a message via Skype™ to scubieman
Do you have too washers in there? Do you at least have one? Maybe take both apart and check the valves for simliar and different to see if something is missing.
2009 Dodge Ram Mega Cab 2500 6.7 cummins
2011 Forest River Cherokee 28BHKS
scubieman is offline   Reply With Quote
Old 05-16-2011, 10:27 PM   #3
Adony's Avatar
no washers needed
The valves (inlet connections) are identical. The inside of the valve inlet connection tube is beveled to seat with the rubber compression type connection which is a part of the hose connector.
Old 05-16-2011, 10:48 PM   #4
rracer5's Avatar
May be that "angle" of the pic you posted but, the elbow looks crooked and that may be causing the ball & seat not to seal properly.
"PT Crew Members Since 9/2010"[/I][/B]
2014 Sanibel 3250
rracer5 is offline   Reply With Quote
Old 05-17-2011, 08:02 AM   #5
Herk7769's Avatar
If the stem is not centered, it will leak.
It could also be defective.
HAM CALLSIGN - KC3FFW
Old 05-17-2011, 09:01 AM   #6
Adony's Avatar
poor picture
The picture was taken with the shower enclosure hanging outside the mounting hole on the trailer.. poor angle to show anything accurately.. I checked the seating of the fitting and it appears to be vertical OK.. I will check for burrs inside the valve inlet tubes where the fitting rubber seal seats.. for something this simple it is getting unreal to stop a silly drip.
Old 05-17-2011, 11:13 AM   #7
rracer5's Avatar
Yup, I was just thinking the same thing about the valve body having a "little" burr or defect in it. Just for Ha, Ha's, switch the two lines and see if the other side has the same drip. If it does, then you know your new fitting is defective. Good luck.
2014 Sanibel 3250
