Originally Posted by iluvlcy
Where is it leaking from? We had water on floor, recaulked around the glass and walls and I even did the "buttons" that are all over the wall inside shower, no more water.
I did the exact same thing. I put toothpicks under the plastic rivet button heads and filled in under them with silicon then removed the toothpicks and wiped off the excess.
The only water that ever showed up was a very small amount on floor against the wall between shower and vanity. I'm pretty sure it's no longer leaking.
