Old 12-02-2009, 09:26 PM   #1
Fishfireguy's Avatar
LEAKING SHOWER- Possible easy fix for the 2010 Survyor Sport 186
I just got my trailer back from our dealer today. Big shout out to Mike Friend RV in Chico, CA. They have been OUTSTANDING on every issue we have had. Anyway, I'm attaching a few pictures to show what they did. We will see how it works hopefully soon. The idea is for the water to run back into the shower base instead of out onto the floor. I'll report back but wanted to give those of you with the same problem a possible solution. Feedback would be appreciated!
ID:	1997   Click image for larger version
ID:	1998   Click image for larger version
ID:	1999   Click image for larger version
Fishfireguy is offline   Reply With Quote
Old 12-15-2009, 11:46 AM   #2
DCRC's Avatar
You use a shower curtain with this? I thing a neo angle shower door set up would be alot better. I still had problems with the shower door set up on my Rockwood 3001W. I end up removing the shower door and running a good bead of sealing where the outside edge set and lowered the shower door into the bead.
Sealant on the inside edge as factory installed would not work because water would get inside the glass and metal frame. I also remove the glass in each panel and ran vinyl tape down it to take up space in the gasket.
It was frustrating. I must of removed and installed the glass shower door 4 times till I came up with a system that worked.
DCRC is offline   Reply With Quote
