Old 05-20-2011, 08:42 AM   #1
Leaky Roo
Just got our new 2011 Rockwood Roo 233 S home.
It's sat outside for a few weeks, and just two days ago, we had a wicked rain storm. Found water on the stove top. Just above it, is the Radio, and there were drips formed at the bottom of the plastic radio cover where it mounts in the cabinet. I've checked the roof, and it looks perfect, can't see any holes, or areas where the caulking got missed. Thought maybe it was running down the antanae and into the trailer, can't see nothing tho. And the cabinet has no access to look inside, the microwave is right beside it.
Has anyone else had a similar issue?
I'm gonna look to see if I can pop the radio cover off, and see in past the radio unit...
Les "Leak Hunter" Block
lessarablock is offline   Reply With Quote
Old 05-20-2011, 08:51 AM   #2
Rugged Brown's Avatar
Water may be coming in from the range hood vent. Especially evident during windy rainstorms. Have noticed it in every camper I have had.
Terry/Bernadette
Lily the Yorkie
2019 Dodge Ram Sport 1500
2019 FR Vibe 28RL
Rugged Brown is offline   Reply With Quote
Old 05-20-2011, 08:52 AM   #3
les,
Is your hood vent for your stove behind where the radio is? If so the water may have entered there. Take the radio out and check. There should four screws holding it in.
Good luck,
gsjp
gsjp1989 is offline   Reply With Quote
Old 05-20-2011, 09:20 AM   #4
Triguy's Avatar
If it is coming in from the vent for the hood, is it possible that the vent on the outside of the trailer was not closed? I thought there was a flap that should be latched down when traveling. Its been awhile since I looked at the outside of the unit, though, so I could be wrong.
Scott
DW, 3 Kids and our Goldens
2012 Shamrock 233S
2008 Toyota Sequoia 5.7L 4WD
Old 05-20-2011, 09:26 AM   #5
No experience (thank goodness!), but I hope you find where it's coming in at. GL!!
Kristina
2016 Rockwood Premier 2317G
2021 F150 XLT
Previously:
2005 Fleetwood Seapine, 2012 Rockwood Roo
2015 Sunseeker, 2017 Fleetwood Pace Arrow
hockeytownmom is offline   Reply With Quote
Old 05-20-2011, 11:01 AM   #6
Even if it is latched down, sometimes, with high winds and driving rain, water will find its way in through the vent.
Terry/Bernadette
Lily the Yorkie
2019 FR Vibe 28RL
Old 05-20-2011, 11:39 AM   #7
Triguy's Avatar
Exactly, I wonder also if he had it latched down in the first place which would have just let in more rain.
This is assuming that the hood vent is the culprit.
Scott
2012 Shamrock 233S
Old 05-20-2011, 02:22 PM   #8
Wow, this is just awesome! So glad to see all the responses so quickly!
Being the detective I am, and the perfectionist, I just had to find out where the water was coming in, and I found it! I took the speaker out (3 screws), and went up on the roof with the garden hose and sprayed a bit. Found it right away.
See the pics...
Thanks all.
Les and Sara.
ID:	5892   Click image for larger version
ID:	5894   Click image for larger version
Old 05-20-2011, 06:19 PM   #9
Triguy's Avatar
Glad you found it, Sherlock!
Just, what is that wire?
Scott
2012 Shamrock 233S
Old 05-20-2011, 08:24 PM   #10
You are lucky that this is the only leak you got. On our new 2011 mini lite the leakage was so bad that the trailer was sent to the factory for a major repair. New back wall. new menbrane etc etc. We are happy now. I wish my problems would have been small like yours.
capucine is offline   Reply With Quote
Old 05-20-2011, 09:47 PM   #11
That same leak i had in my Roo. also the air conditioner, sky light in the bathroom, leaky bed end seals and leak in the seams in the bed ends. Now we get back from a week camping trip and one end of the slid out has fallen about 1 1/2 inches. I hope you have better luck.
Tom T is offline   Reply With Quote
Old 05-21-2011, 10:23 AM   #12
bikendan's Avatar
Congrats on good detective work!
i'm glad you didn't have any bunk leaks. sounds like the newer seal designs are working.
Old 05-24-2011, 10:54 PM   #13
I have had bunk leaks. they added one more seal on the door part. They put a seal on the top and part way down the sides. So now there is the two on the trailer and two on the door. I still have a leak sometimes when i am driving but i put a towel on the floor to catch it.
