Old 09-28-2019, 10:55 AM   #1
Smile LEDís
I turned my LEDís under my awning on with the switch located just inside the door. However, when I used the remote to change the color, the switch will now not operate them. It did this before and I canít remember how to get them back to switch operated. They will come on and go off with the remote, but the switch does nothing. How can I get them back to switch operation?
sandnpalms is offline   Reply With Quote
Old 09-28-2019, 11:34 AM   #2
cboss's Avatar
Is there a function on the remote to go back to switch operation?
Actually this is a little confusing. Normally the switch would remove power from the LEDs.
Craig & Cath
2018 2902WS Rockwood Ultra Lite
2017 Ford F250 Lariat, 6.2 gas
Equalizer Hitch w/ 4-Point Sway Control
Days camped since 2016(retirement): 669
cboss is offline   Reply With Quote
Old 09-28-2019, 08:06 PM   #3
There is not. It is weird.
Old 09-28-2019, 08:09 PM   #4
I just figured it out. Once you use the color coded LED remote, you must turn the lights off with the white general remote before the switch will work again. ����*♀️����*♀️
led
