Old 05-14-2011, 10:33 AM   #11
DirtSquirt's Avatar
Originally Posted by dimurrrw View Post
A long shot, but try spraying both sides of your trailer/truck plug with electronic parts cleaner.
Originally Posted by showtime0022 View Post
Auto parts stores sell gel for contacts to prevent corosion. Think its like 2-3 dollars
I will definitely try both of these things.
2010 Rockwood Roo 23RS
2015 F150 Lariat Supercrew 3.5l EcoBoost. Used to tow with 2006 F150 XLT Supercrew 5.4l V8. The EcoBoost is so much better!
DirtSquirt is offline   Reply With Quote
Old 05-14-2011, 10:37 AM   #12
DirtSquirt's Avatar
Originally Posted by sherdep View Post
the other thing to look for is climb under the trailer and check the wires - maybe a rat or rodent ate the wires
or check to see if you have any connections have corrosion on them
I will do this
Old 05-14-2011, 10:44 AM   #13
DirtSquirt's Avatar
Originally Posted by windrider View Post
Go back, and check exactly what isn't working, and what is. Your original post you stated, "neither of the signal lights or the running light are working on the left side". The brake light, and the signal light are the same wire, bulb, and filament. Also please tell us what you are towing with. If any of the parking lights are working, there is a problem in the trailer. Usually a junction box mounted on the tongue somewhere. All the parking lights run off of one wire from the tow vehicle. If you have only one turn signal, or one brake light, could be the trailer or tow vehicle.
I will hitch the truck up to the trailer today and try to figure out exactly what is and is not working and report back.
