Old 05-13-2011, 05:03 PM   #1
DirtSquirt's Avatar
Left Side Running and Signal Lights No Longer Working.
Hi All,
Not sure if this is the right category to be posting this under or not so please let me know if I should post it elsewhere.
We own a 2010 Rockwood Roo 23RS. When we put the trailer into storage last winter everything was working fine. When we picked up the trailer last weekend, we found that neither of the signal lights or the running light are working on the left side (driver's side) of the trailer. I think that the brake light was working though. All of the lights on the right side are working.
Could someone please tell me how to figure out what the problem is and also how to fix it?
Thanks!
DirtSquirt is offline   Reply With Quote
Old 05-13-2011, 05:07 PM   #2
DirtSquirt's Avatar
Outside Lights not Working.
Silly question I'm sure...
We own a 2010 Rockwood Roo 23RS. There is a light outside right by the door and another one up at the front of the trailer. Both of them worked at the beginning of last season but neither of them were working at the end of the season.
I cannot for the life of me figure out how to get into the casing to replace the lightbulbs to see if that is the problem or not. How do I get into them?
If it isn't just the lightbulbs (it seems weird that both would stop working at the same time), what else could it be?
Thanks!
Old 05-13-2011, 06:12 PM   #3
AKA Bluebird
dimurrrw's Avatar
Send a message via Yahoo to dimurrrw
Usually there are locking tabs built into the lens and you squeeze the top and bottom of the lens to release them. The contact points for the bulb may be corroded, clean them with fine sandpaper.
dimurrrw is offline   Reply With Quote
Old 05-13-2011, 06:18 PM   #4
AKA Bluebird
dimurrrw's Avatar
A long shot, but try spraying both sides of your trailer/truck plug with electronic parts cleaner.
Old 05-13-2011, 06:50 PM   #5
showtime0022's Avatar
Auto parts stores sell gel for contacts to prevent corosion. Think its like 2-3 dollars
showtime0022 is offline   Reply With Quote
Old 05-13-2011, 07:51 PM   #6
sherdep's Avatar
the other thing to look for is climb under the trailer and check the wires - maybe a rat or rodent ate the wires
or check to see if you have any connections have corrosion on them
2011 Rockwood Mini Lite 2306 - Matt
2004 Dodge Ram 1500 Qaud Cab 4x4 with 35" tires and 3.92 gears, Dynatech Longtube Headers & Fabtech 6" lift + Superchips with shift Tuning
Nights Camped 2011 (37) - 2012 (16)-2013 (2) -2014 (5) -2015(0)
USMC 91 - 95 - F/A-18 Aviation Ordnance
sherdep is offline   Reply With Quote
Old 05-13-2011, 10:32 PM   #7
Go back, and check exactly what isn't working, and what is. Your original post you stated, "neither of the signal lights or the running light are working on the left side". The brake light, and the signal light are the same wire, bulb, and filament. Also please tell us what you are towing with. If any of the parking lights are working, there is a problem in the trailer. Usually a junction box mounted on the tongue somewhere. All the parking lights run off of one wire from the tow vehicle. If you have only one turn signal, or one brake light, could be the trailer or tow vehicle.
LadyWindrider
2012 Ford F250 ext. Cab 4x4
2002 Jeep Wrangler Sahara
2008 Work and Play 18LT
Old 05-14-2011, 04:14 AM   #8
miatared's Avatar
Dielectric grease.
I had to do this on my bulbs too. The hitch lamp is not really dust or waterproof, so it gets a beating - needs TLC to work.
Denis & Diane
2010 Sabre 31REDS
Ford F-250 2011
* Happy Campers *
miatared is offline   Reply With Quote
Old 05-14-2011, 10:21 AM   #9
DirtSquirt's Avatar
Thanks!
I see this post got moved. Just to be clear though, the lights I was asking about in this post are not the running or signal lights and have nothing to do with the towing lights whatsoever.
The lights I was talking about here turn on from a switch inside the trailer when you are camping. The one light is up high on the trailer by the door and the other light is lower and on the front of the trailer maybe to provide light if hitching up in the dark.
2015 F150 Lariat Supercrew 3.5l EcoBoost. Used to tow with 2006 F150 XLT Supercrew 5.4l V8. The EcoBoost is so much better!
Old 05-14-2011, 10:31 AM   #10
DirtSquirt's Avatar
I could find the tabs on the signal lights but not on the lights I was talking about in my other post. We squeezed everywhere it doesn't seem to want to budge.
