License plate bracket.
The license plate bracket on the back of our Sunseeker is a plastic bracket molded into the tail light.
It hangs down from the bottom of the tail light, and isn't quite flush with the rear of the RV, so the bottom of the plate isn't mounted, and sticks out about an inch.
I'll bet the plate flaps in the wind, so I want to mount the bottom of the plate to the RV. That plastic bracket can't be good for too much flapping and I don't want to lose it.
It might be adequate to use sheet metal screws to secure into the composite panel, but the engineer in me wants to use anchors.
Has anyone done this?
What kind of anchor should I use? The license plate anchors I've seen snap into pre- punched square holes, with retainers that grip a specific thickness of metal or plastic. I haven't seen any round anchors like this.
