Old 03-30-2014, 09:58 AM   #1
License plate holder
I'm looking for suggestions on how to remount our license plate without needing to buy an entire rear light on our trailer. We have a Roo and our cover caught the license plate as we were taking it off. It appears that the holder is an integrated part of the rear light so I cannot just buy a new bracket to install. Has anyone else had this happen to them and how did you fix it? Pictures would be great too! I wanted to just mount it elsewhere but we need the white light it provides at night for state regulations.
Ladyhawke is offline   Reply With Quote
Old 03-30-2014, 10:04 AM   #2
Rrickim63's Avatar
Pictures of your damage could help us figure out a solution.
1999 Silverado with tow package
2006 Roo 23B hybrid
2006 Roo 23B hybrid
2006 Ford F150 4.6L
Rrickim63 is offline   Reply With Quote
Old 03-30-2014, 10:11 AM   #3
We replaced the taillights on our unit and I gave the Factory (Light/LP bracket) to a FRF member in Calf. I mounted the L/P on the ladder of our unit.Your ROO spare tire cover nut should allow you to mount a L/P bracket. A wire can be run for the light if needed. Youroo!!
Old 03-30-2014, 10:22 AM   #4
Ford Idaho's Avatar
Buy two.
Corner Braces by VALUE BRAND - Braces and Reinforcement Hardware by Zoro Tools Industrial Supplies
Screw the plate to them and hold it to the light, use a sharpie to mark two spots for a drilled hole, one for each.
Remove the lens check for clearance when drilling holes.
Screw/bolt the braces to the light replace lens.
Old 03-31-2014, 08:26 PM   #5
I used something like this:
Universal License Plate Bracket | B428-09 | Nuera Trailer Parts
I pulled the light, modified the bracket to fit/work and then remounted the entire assembly. I think I picked up the piece in the trailer supply section at Academy or Tractor Supply.
ST Williamson
Current TV:'14 F350 Lariat CrewCab, 4x4 Short Bed SRW Diesel w/ Pullrite 2700 (16K)
Current
Fiver: '15 Puma 295BHSS Anniversary Edition
Past TV: '13 F150 HD Payload SCrew EB, '08 Tundra CrewMax 5.7L, '02 'Burb 5.3L, '97 Dakota 3.9L
Past Trailers: '09 Wildwood LE 27RB, '02 Palomino Yearling RL, '87 Jayco 1006dlx
campingwilliamsons is offline   Reply With Quote
