Old 09-16-2011, 07:23 PM   #1
Villa Estate 392FLFB
The_Stuff's Avatar
Lights do not turn on immediately...
So as of late we have noticed that turning on the lights in the living room area can be anywhere from instantaneous (which it should be) to about a 5 minute wait for the lights to finally come on.. now it doesnt take a rocket scientist to figure out that is not normal.
everything else 12v works properly, other lights, radio, etc.
So do you guys/gals think this is a switch or possibly a battery issue? im leaning towards switch myself. Anyone else ever had this issue?
One state/province at a time!
The_Stuff is offline   Reply With Quote
Old 09-16-2011, 07:44 PM   #2
TURBS's Avatar
you may have a bad gfci making minimal contact . I have seen weirder things happen with a gfci . The ones in a rv are the cheapest made .
Old 09-16-2011, 07:59 PM   #3
The_Stuff's Avatar
Guess I should mention it's a 12v lighting issue on traditional rv light switch that is a 3 switch bank. Inside outside and step lights in one unit w 3 switches total.
Also how does one take those apart to check in behind??
Old 09-16-2011, 08:02 PM   #4
wvfireboss's Avatar
Had the same problem in my bathroom light, checked switch which was ok, then I removed light fixture from celing and found bad wire connector, easy fix.
Ron & Barb
2004 GMC 2500
2010 Wildwood 29BHBS
wvfireboss is offline   Reply With Quote
Old 09-17-2011, 06:44 AM   #5
Herk7769's Avatar
I am with Ron here. Corroded or loose fixture or switch wiring.
Pray for loose. Corroded could mean water intrusion issues.
HAM CALLSIGN - KC3FFW
Old 09-17-2011, 07:26 AM   #6
The_Stuff's Avatar
thinking its definitely the switch. this morning i pushed and wiggled the switch and it flickered and i pushed again and they came on. so gotta pull that apart.
Old 09-21-2011, 07:33 PM   #7
The_Stuff's Avatar
anyone know how to get the switch apart??
Old 09-21-2011, 07:39 PM   #8
sherdep's Avatar
If you can jiggle the switch and the lights flicker and come on and off - you probably have a bad switch like you said - I vote switch
you might have to get a small screw driver behind the switch and push the top side in to pull the switch out - if I am not mistaken the switch has a raised piece on top and bottom in which it is held into place that way - if it is the same switch I have in my Mini Lite for say like the bathroom lights.
I attached a picture of a toggle switch - look at the raised pieces - those are what hold it in place
Name:	Toggle Switch.jpg
2011 Rockwood Mini Lite 2306 - Matt
2004 Dodge Ram 1500 Qaud Cab 4x4 with 35" tires and 3.92 gears, Dynatech Longtube Headers & Fabtech 6" lift + Superchips with shift Tuning
Nights Camped 2011 (37) - 2012 (16)-2013 (2) -2014 (5) -2015(0)
USMC 91 - 95 - F/A-18 Aviation Ordnance
sherdep is offline   Reply With Quote
Old 09-21-2011, 07:49 PM   #9
The_Stuff's Avatar
yup. i poked and prodded with the screwdriver and found out how to get her open.
wires look good so i assume its the switch.. I so want to find one like you posted with the light!
Old 09-21-2011, 07:57 PM   #10
sherdep's Avatar
am pretty sure you can get them at Radio Shack or you can order from Grainger
or possibly check Walmart
