sorry was not very clear. all the running lights work fine when hocked up with the car. its the 30 amp cord at the camp sites
still not real clear here...
the running lights are typically not lit up when you are camping, so if they light at all they should be on while driving...
If you hook to shore power with the 30 amp cord, your inside lights flash?
That would seem to indicate a bad 12 V converter... or camper battery inside your rig...
Your battery may be dead or dying as the interior lights of your camper are powered by 12V which is supplied by your camper's battery and your battery is kept charged by the converter with the 120 VAC you get from the power pedestal via the 30 amp cord.
Your other 120 VAC appliances and plugs will work, but the 12VDC lights flash?
Check for a dead camper battery, then see if the converter will light your interior lights WITHOUT the camper battery connected and report back. You can take the battery out and have it tested at any auto parts store.
