Old 04-24-2015, 10:00 AM   #1
Jestercyco's Avatar
Lippert 6 point leveler FYI
I was setting up our TT last night and the spot was not level and was quite high on the front side. When I went to auto level it did its normal dip to the front and went to the all the way down and kept trying to reach the point to begin the sequence. It finally just stopped and lost all power to the panel. I looked for a blown fuse, none found. I traced the wiring from the panel at 9PM last night, and in a control box on the left side the front storage I found to overloads with a reset on them. I reset the overload and finished by raising the back levelers to compensate for the extreme angle. It was simple after I found it. This is just FYI.
Hope it will help if some ones gets in trouble.
Jester
2012 Super Crew 4WD 6.7 PSD
2015 Cardinal 3800 FL
2007 Road King Black Cherry-Hers
2007 Road King Blue-Mine
1979 FXS Hot Rod Shovelhead
Jestercyco is offline   Reply With Quote
Old 04-25-2015, 09:24 AM   #2
14 CC 38CK's Avatar
Thanks for the info. Just wish most camp grounds could level better than what they do for the money they charge
14 CC 38CK is offline   Reply With Quote
