Thanks for the information. When we got our Georgetown, we also had a leak in the connections at the tank and manifold. We also had two jacks that needed replacing. Forest River replaced the jacks and I fixed the leak (tightened the fittings). And now leave a folded paper towel in the tank department to watch for leaks. One of our slides also did not come in one time but was able to move it in manually. We found out that our batteries were low and caused a circut breaker to trip. that is located on the frame behind the batteries. there is also a fuse that can go bad on the slides adjacentto the circut breaker in a box mounted on the frame. I talked to the Lipper engineers and they said to keep the tank full (one inch from the top). That way air will not get into the pump and cause problems with the opening of the slides and jacks.
People have bad mouthed Lippert, but they have treated me fairly and stand by their product. You should hear some of the horror stories about electric slides and jacks on expensive diesel pushers.
