Old 11-10-2013, 09:04 PM   #1
Lippert leveling "not level"
I own a 2011 georgetown 373ds..when leveling the motorhome with the auto level (lippert system) it levels out but the coach is not level when complete....any one with this problem or any ideas what could be wrong..side to side is ok..front is always low....thanks pennstaterv
pennstaterv is offline   Reply With Quote
Old 11-11-2013, 07:52 AM   #2
TURBS's Avatar
The leveling device needs to be "re leveled"
If its off level it will off level your ca camper.
Turbs
Old 11-11-2013, 12:14 PM   #3
Anacortesians
I only used the auto system on my Georgetown once. It kept getting higher and higher as it tried to level and finished up almost lifting all four wheels off the ground. We needed to be roped together to make the climb from the ground to the bottom entry step!
I make it standard procedure now to level manually, using as little jack extension as necessary. I set a datum for myself by putting a 12" level in the bottom of the fridge and getting the rig level in both axes. I then attached two stick-on levels (one for each axis) near the driver's seat where I can see them when operating the leveller controls.
Frank and Eileen
No longer RVers or FR owners
Old 11-11-2013, 12:17 PM   #4
The "auto" leveling system has the propensity to lift the front tires off the ground regardless of the site level characteristics! Manual leveling is the best option!
Our 2008 Georgetown 374 has been this way since purchase!
George
ynott96 is offline   Reply With Quote
leveling
