12-12-2011, 03:40 PM
Lippert Slideout sticking (Lippert)
I have the Lippert above floor slide out system. When I retract the slide, in position, the upper left (Looking from the outside) will not fully retract. It stays away from the inside wall about two inches and must be manually pulled in using the slide out lock bar.
The problem is the slide out is lower on the left side the left causing it to pinch the upper left side (pulling the rubber gasket in) and needs to be adjusted/lifted. If anyone has had experience with this repair I'd appreciate any tips/hints/input.
Link for Lippert above floor slide out system
www.lippertrepairparts.com/pdf/Above%20Floor%20Sofa%20Slide-Web.pdf
"If everything seems to be going well, look around, you've obviously overlooked something."
| Thread Tools |
| Display Modes |
» Recent Threads |
» Online Users: 710 |
| 150 members and 560 guests |
| Alisa06, alpinemike, artnlisa, bagged123, BeagleIL, Bearcat55, bikendan, blaisrv, BlakeB, bo criswell, boubou, brady, brookside, Buffalohunter, Cafjackracing, camper1953, camping4us, Cascade Bob, cat1956, CCrane2299, cdbus, chof16, ChrisZazzara, ColoradoGreg, Cowracer, creed, Csbower, cstover, cyclepuck, DAISY BOYKIN, danielpburke, danred, dapersico, davidjb, dfrauhiger, djorgensen3, dnaraG_1M, doc73, donn, doosterhouse, drobert, duchie, dunnnc, dustman_stx, emljr, Emptypockets, extremebike, f1100turbo, Falcon35, Fire Instructor, Flashg_123, Foneguy, fpdeod, gator14, gmw65, grhodes50, HemiCab, Hilgy, hokiecampers, hotrodj125, irish01, Itsthetwoofus, jamesroadking, Janet H, jar3316, jkinger, jrb988, kegoneill, Kevin-and-Julie, KKapa, klucas, KyDan, lbhird, ldmcmahan, ldprice47, LFugate, lmcleister, lochsa, Loopyhamil, Malco, Mark S, mbrwr, mhartzel, michaelpike, Michigan, Mickey1, mike2tall, MIKE44460, milw156, Mnflyboy, nailit, Nursx2, OffPavement, PAMROBERTNC, pandkm, papap, PaulK, phone man, photog, Piston, pmsherman, popbreed, Ptmaazx6, punkaccountant, pwadini, RattVader, redfox217, rgmiller32, rick51, RJHuser, rkswyo, rob2112, Rogue69, rotorhead1250, SabreSam, Sahgie, sail2liv, Sailfish Bret, scout800, scroses40, SDENN4281, shane1234, shrimper, silly2635, SimchaSabre, skeeterbait8, Snowsail, stevem4134, T.Kott, TacBear, tbritt, Tee, Test Account, texashatter, Timex, Titleguy, tlc, tmmar, trailraider, travyp, Triguy, tshayn, vlite2011, wagon52, Warrior, washdweller, wayne anthony, william.migues, wnytaxman, Zadnichek |
| Most users ever online was 944, 03-04-2012 at 01:27 PM. |
