Old 06-14-2019, 10:08 PM   #1
Lippert Solid Step - keep showing up damaged
Alright - post up your LCI Solid Steps door tabs!
I've purchased two LCI 3-step 28" Solid Steps now and the tabs that rest in the door jamb have been bent from what I can tell. I believe based on photos on e-trailer, etc that these tabs should be fairly right-angles and include some sort of rubber/plastic cab to protect against rubbing on the door frame because there is residual glue on the metal tabs but nothing.
Can anyone else confirm with photos how these tabs look and if plastic covers should be there?
ID:	207367   Click image for larger version
robertaleon is offline   Reply With Quote
Old 06-15-2019, 07:11 AM   #2
Those stops do not have a rubber covering on mine and all of the bends are at sharp right angles.
I have seen several of these steps on other trailers, and they are the same as mine.
Bruce
Old 06-15-2019, 07:22 AM   #3
Here is the photo confirmation that I failed to include in my post above:
Bruce
Old 06-15-2019, 03:21 PM   #4
Hi,
Mine (going into third season of use) are right angled, they have not bent or deformed, and there are no bumpers.
FWIW.
Rich Phillips
Rich Phillips
2019 K-2500 Duramax Crew Cab
2014 Silverback 33RL
richp is offline   Reply With Quote
Old 06-16-2019, 01:09 PM   #5
Telstar's Avatar
Depends who you bought it from. I bought mine from Camping World, shipped by FedEx. It took 3 to get one that wasn’t defective. I talked with Lippaert, was told due to the flimsy box they are shipped in there is a better than 50% chance of shipping damage. They ship from factory on a pallet. So pay a little more for truck shipping on pallet.
Gary and Donna
2005 Cardinal 33TS-LX
Trail Air pin box
Center Point suspension
2018 Ram Laramie 3500 6'4" box 2WD
Demco AutoSlide 18k
Telstar is offline   Reply With Quote
Old 06-16-2019, 02:45 PM   #6
rlh1957's Avatar
That's shipping damage. Not supposed to look that way.
2018 Forest River Rockwood Roo
24WS
2019 Ford SD F-350 SRW Lariat
Tow & Gooseneck Prep
FX4 Off Road (4X4)
rlh1957 is offline   Reply With Quote
Old 06-16-2019, 04:00 PM   #7
CaptnJohn's Avatar
Those steps came on my 2019, yes at right angles and a junk plastic sleeve cover the end. Duct tape would do a better job. Dumping them before next summer for aluminum pull out steps.
2019 Montana 3761 FL
2019 F350 6.7 4X4 LB Dually
Edgewater 205 EX 150 Yamaha
Old 06-17-2019, 05:19 PM   #8
Before I go and try my attempt at a 3rd time on these steps - Why are you getting rid of them CaptnJohn? I'm always drawn to them on the lots but imagine having them in the field under normal use gives you more insight.
Old 06-17-2019, 05:34 PM   #9
madatme's Avatar
my steps are fine also, can you bend them back?
2019 FR Vibe 28RL
2018 Silverado 1500, Husky Centerline TS
3 Great Danes, 1 Weimaraner
Wonderful co-pilot
madatme is offline   Reply With Quote
Old 06-17-2019, 06:46 PM   #10
frank4711's Avatar
Quality control always seems to be issue or in this case is it packing/shipping ... we like ours a lot ... one thing they need adjustment every you camp to ensure legs are flush and door swings free and clear ...
Frank & Cindy *** Rockwood Ultra Lite *** 2019 Ram *** Remi & Sage traveling Pomskies *** TST 507 TPMS *** B&W Patriot 18K *** 3.92 axle *** Goodyear Endurance *** 44 days camped 2019 *** Predator 3500
frank4711 is offline   Reply With Quote
Old 06-30-2019, 07:45 AM   #11
Have you looked into the Mor-ryde units instead? Same basic design.
Nosedive is offline   Reply With Quote
Old 06-30-2019, 11:33 AM   #12
Telstar's Avatar
Newer trailers have a higher door sill. Ours is a 2005 and when I called MorRide and discussed measurements they told me theirs won’t work on ours. I did have to do modification for the step above; shaved off the lip under the door on the outside, routed out the hardwood flooring so the plate could sit on the plywood subfloor and notched the door frame to provide clearance for the locks that hold it closed. End result is we are extremely happy with it.
Gary and Donna
Trail Air pin box
Demco AutoSlide 18k
show
