Originally Posted by JimChow
Has anyone ever rotated the tongue jack head/motor 90 degrees ? The reason for asking is our rear hatch on out 07 Tahoe hits the switches on the tongue jack when opening or closing. If I can rotate the head 90 degrees I would eliminate the problem.
The motor and the jack itself are connected by a pinion gear. No reason why you can't loosen the head and rotate it, just be mindful of the power lead and don't wrap it around the shaft housing too tightly.
