Originally Posted by mkampling
Hello friends!
Ran the tongue jack up too far this morning apparently...blew the 30a fuse (fixed) and jack works fine again. Looked at the emergency crank nut on top and cracked it into smithereens. So, a couple of questions...
1. Leaving tomorrow for 2 weeks on the road. No time to replace the jack now. Seems to work fine for now, hoping for the best...has anyone done this before? Any luck with the long term survivability of the jack? Think I have a work around if necessary while traveling- should I replace when I settle in MI for a few days?
2. I looked everywhere for a replacement nut- most tech sites I saw say its a non-replaceable part. Anyone found a part # or workable replacement they can share?
Thanks!
Kamp
Kamp, I am not very familiar with the Lippert jacks, but what is the plastic nut attached to? If it is a metal stud of some sort, you may be able to use an acorn nut if threaded, else you could use a regular nut and just tack weld it to the end of the shaft. If it has to be a plastic nut to attach to the stud, you could line the inside of an appropriate socket with a piece of celophane wrap and fill with JB Weld on the stud. Once it hardens, it should serve as an emergency nut to raise or lower the jack manually.
I've blown the fuse on my 3500# tongue jack and after freeing up the motor, it has been working fine for the last 4 years...luckily, mine has a steel nut for the manual operation. To keep from running mine too far, I put some colored tape near the minimum and maximum lengths to allow on the extension.
Good Luck with the repairs ,,, Swampy
