Old 03-23-2016, 01:01 PM   #11
Yes I do have one for my house, of course I built it myself.
2016 Flagstaff 23lb
Toddupton is offline   Reply With Quote
Old 03-23-2016, 01:03 PM   #12
Too Tall's Avatar
No, a schematic may not indicate the exact location of a plumbing line or wire (IE: 1-1/2" from wall "A") but they sure do tell you a lot about what makes up those lines/connections. Knowing whether a particular run is a home run or has feeders off it would be huge knowledge to have when troubleshooting a problem.
I've been following the OP's original post about his problem and a schematic would be tremendously helpful for what he is trying to solve.
EDIT: we once owned a modular home that we were provided with schematics for all the HVAC, plumbing, and wiring. They do exist.
Absolutely, IMO each model should have a design showing electrical schematic and plumbing. Turning workers loose on an assembly line and saying just put it where you want is not efficient and would explain why there's so many issues.
Rockwood 2104S, 2014 Ram 2500 Diesel.
USMC 68 -70
Too Tall is offline   Reply With Quote
Old 03-23-2016, 01:44 PM   #13
CDR USN Ret
Originally Posted by Jim34RL View Post
What is a schematic? The schematic show's a tank, a pump, a holding tank ( hot water heater), accumulator and a valve. It will also show connections between each component. But the schematic will not show the line routing i.e. line drawing of piping/ tubing. In some industries this is not a requirement for manufacturing especially if PEX tubing is being used. I also think a schematic would be useless to most individuals as they would not understand the international symbol for most components that are used in a schematic drawing.
Do you have a wiring diagram and or a water line drawing for your main residents that you live in?
From a retired hydraulic engineer.
No, but my home was wired to codes (requires all connections to be in boxes, and these connections to be accessible, etc.) NFPA 1192 falls far short of a true code document. RVs, being relatively non-standard, are far more like a commercial building - and "as-built" drawings are very common in that environment.
My plumbing in the home did not include black/grey/fresh water tanks with concealed dump valves, level indicators, tank vents, tank overflows, flush devices, anti-siphons hidden in walls, behind medicine cabinets, under lavatories, etc. I knew generally what components were there, and about where the were located, because code specified what and where.
All you've got to do is see the number of RV owners with tank flush valve problems, dump valve problems, hidden coax splitters, circuits with wire nut connections which have fallen off.
As far as understanding symbols - google.
from a retired mechanical contractor.
2015 XLR415AMP
2011 3500HD Duramax/Allison/90 Gal Aux
2015 HD Limited Low
DSQR is offline   Reply With Quote
Old 03-23-2016, 01:47 PM   #14
CDR USN Ret
And makes it very difficult for a comprehensive QA check during manufacture.
2015 XLR415AMP
2015 HD Limited Low
Old 03-23-2016, 03:10 PM   #15
Location: North of I-10 & South of I-94, but East of I-5 & West of I-95
RV Manufacturer's have Quality Checks?
2nd House is offline   Reply With Quote
Old 03-23-2016, 04:17 PM   #16
It is imposeble to have a Q&A if you dont have a complete detail diagram of each section of the trailer!
The good responseble industries call that the blue print diagram.
Jonol is offline   Reply With Quote
Old 03-23-2016, 07:26 PM   #17
Originally Posted by beachcamper View Post
I don't think it's wrong, just different. The floor plan dictates where everything goes. Who ever puts in the plumbing just connects everything the way they like. As long as it works who cares how exactly the plumbing or electrical wires for that matter are routed.
I care!!!
pdqparalegal1 is offline   Reply With Quote
plumbing
