Old 09-19-2015, 01:02 PM   #1
Loose Tape On The Undercarriage
We just purchased a Forest River Wildwood X-Lite 231RBXL the first part of the year, and we've been pretty happy so far. I'm getting ready to winterize it coming up, but I've noticed on the underside that there's a black tape that looks like it's used to help seal areas where lines run through the bottom of the trailer; it reminds me of wide black electrical tape, or black duct tape. I've noticed a couple places where the tape has come loose, or has fallen off. What type of tape should I use to replace the stuff that's come loose?
audiocentric is offline   Reply With Quote
Old 09-19-2015, 01:42 PM   #2
Jimcam22's Avatar
I use black Gorilla Tape on mine.
2011 Rockwood 8285WS
2012 F150 SuperCrew Ecoboost HD payload
Curt 20K Q5 Slider Hitch
Jimcam22 is offline   Reply With Quote
Old 09-19-2015, 10:11 PM   #3
Dabmeb's Avatar
X2 on the gorilla tape, works great.
Dabmeb is offline   Reply With Quote
Old 09-19-2015, 10:14 PM   #4
mikkeeh's Avatar
x3
mikkeeh is offline   Reply With Quote
Old 09-20-2015, 07:49 AM   #5
cpaulsen's Avatar
X4! Just clean up the area with some kind of cleaner so it will stick! I used brake cleaner on a rag.
cpaulsen is offline   Reply With Quote
Old 09-20-2015, 01:17 PM   #6
Thanks to everyone for the quick response...I'm off to get some tape!
Old 09-20-2015, 08:14 PM   #7
Rivnut
Rivnut's Avatar
x5.....me too
Rivnut is offline   Reply With Quote
Old 09-23-2015, 07:57 PM   #8
Sc00ter's Avatar
X6. Clean surface and black gorilla tape.
2015 puma 295bhss
2009 ram 3500 6.7l ctd
Sc00ter is offline   Reply With Quote
Old 09-23-2015, 08:07 PM   #9
trbomax's Avatar
My question would be why is there any tape in the first place?
trbomax is offline   Reply With Quote
Old 09-23-2015, 08:44 PM   #10
Had a water leak on our camper and the dealer cut the underside to gain access to the hose fittings rather than taking it all off; guess it saved a lot of time. The Gorilla tape held for the two years we owned it.
Sirsea is offline   Reply With Quote
Old 09-24-2015, 11:02 AM   #11
Jimcam22's Avatar
Mine was for access to the main slide motor when it had to be replaced.
Old 09-24-2015, 11:47 AM   #12
trbomax's Avatar
I have tape all over the bottom of mine to. It came that way,but it should not have. My attitude about the tape thing is that if they had to cut a hole in the roof or sidewall would it be OK to tape it back together? When the tape under there comes loose and starts letting road wind(not to mention dirt and water) in,you wont know it untill it tears the belly off and you are dragging it down the road.
Old 12-23-2015, 03:11 PM   #13
I might not worry too much about having tape in small areas (like where the lines run thru), but like some other posters, I have two strips of tape from side to side where a local dealer patched the undercarriage back together. My fresh water tank had to be repaired and the undercarriage was cut all the way across in two places. That was only months ago and the tape is already falling off. I'm still under warranty. Would it be unrealistic to ask the dealer to replace the entire undercarriage in one piece, like the way it came delivered?
2015 Wildwood Heritage Glen 35'
2015 Chevy Silverado 2500 HD
eresidae is offline   Reply With Quote
Old 12-29-2015, 06:50 PM   #14
I go RV'ing not Camping
jgourlie's Avatar
It wouldn't hurt to try....I think the dealer should also have access to some different types of tape that is a lot stronger than say duct tape etc..
312QBUD Owners Thread
2015 Wildwood Heritage Glen 312QBUD
2000 Chev 2500 Extended Cab 6 Liter
1400lbs Equal-i-zer Hitch
jgourlie is offline   Reply With Quote
Old 12-29-2015, 06:58 PM   #15
Platokidd's Avatar
RV underbelly tape should be no problem for small stuff..
Pick up some corrugated plastic, cut to size and screw it in.
2014 LaCrosse 323RST-TE-C
2009 Chevy 2500HD Z71
Seasonal
Zelda the campin dog
