Old 04-24-2015, 02:42 PM   #11
Made an appointment with Tampa truck center they are a certified Mercedes repair shop with the correct diagnostic computer obd2 will not work with this system lower tech. This unit does not have the dpf fluid not sure what that is the older units used it. Not a turbo eng hope it's just a computer flash everything is like new. Will update when I get a diagnosis.
Travelinman is offline   Reply With Quote
Old 04-24-2015, 03:12 PM   #12
I agree on it being a firm ware issue. I had a similar issue with my tow rig and it ended being 2 things they needed to up date the firm ware and they had a recall on one of the computers over heating causing issues. They installed a larger fan on the system for cooling. No problems now.
j free is offline   Reply With Quote
Old 04-24-2015, 04:42 PM   #13
A friend had the same problem with his Class A Freightliner. Turned out to be a bad sensor. I think it was the water in fuel sensor. Happened several times. Finally got to a Freightliner dealer who diagnosed it.
RamblerGuy
2011 Sunseeker 3100
1997 Pathfinder Toad
Old 04-25-2015, 03:08 PM   #14
I had a 2009 sprinter with that same problem, ended up to be the EGR valve replaced it end of problem
northdakota is offline   Reply With Quote
Old 04-29-2015, 10:36 AM   #15
Ok guys got the good and bad news I was able to get it into limp mode and took it right to Tampa truck center they did an express write up and found a soft code for the egr valve. Bad news is they want 1.100$ to replace it.I am a little shocked at 17k but who knows have read that they can be cleaned I am a certified master mech and think I will give it a shot if not I will replace it.
Old 04-29-2015, 01:24 PM   #16
Life was much less expensive before emission control... sorry to hear that. Good luck cleaning the one you have. Please post results.
Douglas Houston
Flower Mound,TX
1999 2500 Suburban
2013 WFKSS-30 V-Lite
2015 - 209 days
dhouston16 is offline   Reply With Quote
Old 04-29-2015, 01:30 PM   #17
TURBS's Avatar
I bet if you look around someone is offering a egr delete for that unit.
Unless by law you are required to pass an emissions test
TURBS
08 duramax tuned n modded, 32bhok Sabre
2015 camping "2 nights"
Old 04-29-2015, 01:32 PM   #18
TURBS's Avatar
http://m.dieselspec.ca/6-brand-mercedes.html?cat=2
TURBS
Old 04-29-2015, 05:10 PM   #19
After talking with Good Sam and going over the contract the egr valve is not a covered item of course it's not and 1,100.00 is out of the question. Trekked back to retrieve the coach and the svc advisor Nichole took care of me after I explained my situation she only charged me 25.00 for diagnosis not the 125.00 I signed for. The estimate was for 3.0 hrs in labor at 145.00 an hr and 525.0. in parts . Being a tech for many years I popped the hood expecting to see the valve buried and a pia to get out. To my joy it was right there in my face and took me all of 17 minutes to remove. I was surprised to find that it was clogged and the valve was stuck in the halfway position. There were a couple of videos on U Tube about cleaning them and after some further research on the sprinter forum I have found this to be a common problem and a flaw in the design. Going to get some Seafoam cleaner in the am and soak it clean it and reinstall will see what happens if it fails I have access to sprinter parts and my cost for the valve would be 325.00,200.00 less than the dealer.Will keep you posted.
Old 05-09-2015, 05:39 PM   #20
My f150 does the same thing when i manually operate the trailer brakes. Once i got the trailer brake module where i wanted it, it has never done it since.
rominks is offline   Reply With Quote
power, modifications
