Old 12-04-2009, 12:07 PM   #11
I didn't think my trailer had them either but another member with the same model pointed them out. They were WELL hidden. After another trip under I did find them. They might be under the area of the bathroom/shower stall area. Just a thought.
I think they probably all have them somewhere, just finding where is the issue. I think all the manufacturers like to make them as hard as possible to find for some reason.
Hokiehall is offline   Reply With Quote
Old 12-04-2009, 02:32 PM   #12
MtnGuy's Avatar
Originally Posted by ParTimCmpr View Post
Crawled and crawled - no luck. I have pulled the panel where the hot water heater is located under the kitchen counter, and the panel where the water pump is located under the bathroom sink. I did not see valves in either location. However, I will give it all another look.
Thanks,
David
Look for a pipe connection in either of those locations, and any where else you can visibly see the lines. In ours, an ordinary looking connection is actually a tee, with the bottom of the tee going through the floor to the low point drain. If you can find something like that, then look on the outside in that area for the drain. Ours does not have a valve on the inside, just a pipe cap on the outside.
Old 12-04-2009, 04:47 PM   #13
Commercial Member
huntr70's Avatar
Mine technically doesn't have any "valves".
The drains are just 2 tubes sticking down with caps on them, no valves to move or open.
The cold is blue, the hot is red.
Steve and Vicki
2 kids
2011 Dodge 3500 CTD Outdoorsman
(Tweaked!!)
2013 Columbus 320RS-ITS HERE!!
huntr70 is offline   Reply With Quote
Old 12-04-2009, 06:07 PM   #14
The low point drains on mine are located right underneth the water heater between the frame and skirting should be a red and blue with screw on caps no valve for opening and closing but mine is a 2007 model
cma659 is offline   Reply With Quote
Old 12-05-2009, 02:10 PM   #15
mjones12's Avatar
low point and winterizing
My low-point lines were easy to find: two capped lines under the bathroom area. My question is what is the procedure for using them during winterization? I was very confused by the dealer's explanation, and I thought he said we would never need to open them. When I do open them while parked at home, some water comes out, so it seems I will need to be sure I've got antifreeze running out of them when I winterize. Is that right? Can anyone help clear up my confusion? Thanks.
2018 Coachmen Apex 249 RBS
2010 Silverado LT 5.3 V8
The world is a great book, of which those who never stir from home
read only a page. - St. Augustine
mjones12 is online now   Reply With Quote
Old 12-05-2009, 03:04 PM   #16
Depending on how you winterize (blowing out with air or drawing antifreeze through the lines) determines whether you need to open them. If blowing out, open them so all the water in the lines goes out. On my other trailers, I left them open until Spring when I closed them up before de-winterizing.
If you are running antifreeze through the lines, you can still open them to get rid of any excess water, but be sure to close them back. Otherwise your antifreeze will be all over your parking area.
Old 12-06-2009, 08:51 AM   #17
highwayman's Avatar
Low Point Drains? I kept looking! Guess What?
I have a 2009 Sandpiper RLD 332 TT, I was about to give up after an hour of crawling around under the trailer looking for the low point drains. I spotted this clump of sandy mud that looked like it could be something, brushed it away and ta dah!! The bright Red & Blue lines weren't so colorful with the coating of mud, (twenty miles of wet gravel in route to our seasonal spot) plus they were way up under just inside about a foot in from the outside body of the camper. My first clue to check this area was the I saw lines going thru the floor inside the corner of the kitchen vanity. I have no valves, but capped lines.
I drained, and then winterized, noticed I did get a little Pink out of them after opening them up and leaving them open for winter.
Highwayman
Rog
highwayman is offline   Reply With Quote
Old 12-06-2009, 09:32 AM   #18
highwayman's Avatar
Old 12-06-2009, 01:51 PM   #19
MtnGuy's Avatar
II drained, and then winterized, noticed I did get a little Pink out of them after opening them up and leaving them open for winter.
Highwayman
Rog
I recap my lines after I make sure they are drained good........I don't want any kind of little critter crawling up there and contamanating my water lines.
Old 12-27-2009, 07:12 PM   #20
OK - So mine were right where you described. I was so tired after looking so many times, I did not crawl far enough under to see them. They are right against the skirting so you have to look back under the edge to see them.
With that said, I now wonder about what the 'low point valve' really is. But let me start another thread for this one....
Thanks,
ParTimCmpr
ParTimCmpr is offline   Reply With Quote
