Old 06-29-2016, 08:27 PM   #21
MNtraveler's Avatar
You were using quite a bit of power. You probably need to recharge an hour in the evening and an hour in the morning, at least. A voltmeter will give you a roughly good reading on status of charge, but don't try to read after charging as it always looks good them. Read before charging or an hour or more after charging. Keep your batteries up for their own sake and also this will avoid problems with the CO alarm.
2016 Forester 2401R
MNtraveler is offline   Reply With Quote
Old 06-30-2016, 08:08 AM   #22
MilCop4523's Avatar
Originally Posted by bikendan View Post
When dry camping or boondocking, even with two batteries, using the furnace over a weekend(along with lights, water pump, fans, fridge, water heater) can deplete the batteries down enough to activate the alarm.
Furnace usage is the BIG battery drain.
agreed.
I wonder what style of lighting is in the trailer.
I switched ours over to LED lighting and got rid of the battery draining original yellowish lights.
They say 16 LED's running for one hour consume the same as 1 incandescent bulb.
We opt for polar fleece blankets vs the furnace if its only chilly.
I also turn the water pump on only when needed.
Name:	LED lighs.JPG
09 Sundance 31.5 XLT Bunkhouse
17 Greywolf 22rr Toy Hauler
and
The new toy hauler - 2016 Ford F150 Supercrew XTR ECOBOOST.
MilCop4523 is offline   Reply With Quote
Old 06-30-2016, 08:11 AM   #23
You need to shed some of your load on the battery when boondocking. If you have a Dometic fridge, check the circuit board that's accessible from the outside inspection panel. If there's a connection labelled "light/heater" pull the wire off of it when boondocking. The heater this wire feeds is the door seal anti condensation heater strip that draws around 1A/hour. That's 50A over two days, a significant drain on the battery. Do not remove that wire if you're plugged into shore power. The fuse located near it is for the 110V heater and its exposed contacts can give you an unexpected jolt if you touch them.
That wire goes to the interior light and from there to the heating strip. If you boondock a lot, you could install a switch for the heater portion next to the light fixture inside the fridge. Many years ago, Dometic had a separate switch to shut off the heater but it disappeared sometime before 2010.
Phil
pmsherman is offline   Reply With Quote
Old 06-30-2016, 10:15 AM   #24
bpa098's Avatar
Pretty sure my lights are led. I know someone else comment but I haven't used furnace and don't have res fridge
bpa098 is offline   Reply With Quote
Old 06-30-2016, 10:32 AM   #25
MilCop4523's Avatar
power drain somewhere else?
with all items off at the panel check your battery state,
then check teh draw off each breaker in stand by mode.
following one at a time, add one more item at a time and recheck.
there has to be something drawing the battery down.
tV during the day or evening? Stereo on for the radio?
we (my wife means I) killed the trailer and truck battery at the NASCAR races in NH in 2012 while plugged in. lights did me in along with the water pump and watching TV.
Tow Vehicle needed a boost.
and
Old 06-30-2016, 10:40 AM   #26
bpa098's Avatar
In an earlier post on this thread I listed stuff..... inside lights, 3 bed fans, stereo day and night, awning led lights, water pump, think fridge draws some, bathroom vent fan,
Old 06-30-2016, 10:41 AM   #27
MilCop4523's Avatar
thats a lot of power used
time to invest in a suitcase generator perhaps = problem solved.
and
Old 06-30-2016, 10:48 AM   #28
bpa098's Avatar
I know. Guessing you didn't read all the posts lol. I added a second battery this year, was testing it out. We normally conserve much better
Old 06-30-2016, 11:03 AM   #29
TURBS's Avatar
Your fridge draws a good chunk especially from the defrost heat strip that cannot be turned off, however it can be bypassed
2015 Columbus 320RS
2008 2500HD Duramax
2015 nights camped "34"
2016 nights camped "10"
Old 06-30-2016, 02:25 PM   #30
My suspects for power usage are the fans and stereo. Each could be anywhere from 1 to 5 amps. You can measure with a multimeter that has a suitable DC amps range. You do have to break the circuit to insert the meter to get a current measurement.
Fred W
voltage
