Old 11-01-2010, 09:38 PM   #1
lp detector
Having a problem with the lp detector on my 31 REDS Sabre. The fifth wheel is in storage and we went there the other day and the detector started going off. The propane tanks are closed. The battery didn't have enough power for lights so plugged in to tow vehicle and detector shut off. Do I have a propane problem or a battery problem?
jimreflex is offline   Reply With Quote
Old 11-01-2010, 09:54 PM   #2
Battery problem, maybe. The detectors go off when the voltage on the battery gets low. Since your trailer was in storage, and I assume, not plugged in, the detector, and some other stuff, draws the battery down. When you plugged in to the tow vehicle, it started charging the battery, brought the voltage back up enough for he detector to be happy, and quite. If you are going to leave your trailer for long periods of time,(30 days or more), not connected, as in storage, it is recommended that the battery be disconnected. This can be done manually, or by the addition of a battery "cut-off" switch. Search the Forum for "battery cut off" and ye shall find.
LadyWindrider
2012 Ford F250 ext. Cab 4x4
2002 Jeep Wrangler Sahara
2008 Work and Play 18LT
Old 11-02-2010, 12:12 PM   #3
gregm59's Avatar
Ditto on the low battery. I had the same problem. Propane tanks shut off, trailer disconnected from shore power and eventually the detector went off.
2007 Surveyor SV291
Equil-I-zer hitch
2005 Durango Hemi
gregm59 is offline   Reply With Quote
Old 11-03-2010, 10:45 AM   #4
Villa Estate 392FLFB
The_Stuff's Avatar
ditto to windrider's post. either unhook the battery or put a battery disconnect in there.
since it was dead i would take it home with me and put it on a trickle charger for a day to get it back up to charge to!
One state/province at a time!
The_Stuff is offline   Reply With Quote
Old 11-03-2010, 11:25 AM   #5
Wanna Be Camper
SaskCampers's Avatar
Another Ditto to the above.
John & Deb
2011 Flagstaff V-Lite 30WRLS
Days Camped 2016: 3 2017: 0
