Old 06-12-2019, 07:01 AM   #1
LP Gas/CO Detector Fuse
I was replacing the Detector located in the wall below the sink and I accidently touched the wires together and now there is no power. Where is that fuse located? Thanks in advance!
Trish2002 is offline   Reply With Quote
Old 06-12-2019, 07:08 AM   #2
fonzie's Avatar
Look for a 5 amp fuse where your house batteries and battery control center are located. Usually under the entry steps. See diagram below.
Fonzie
Nights Camped:2012(36) 2013 (17) 2014 (18) 2015 (18) 2016 (36) 2017 (32) 2018 (42)
Old 06-12-2019, 09:18 AM   #3
I had this happen a few months ago. I unscrewed the detector and found a blown fuse just behind it. Think it was 5 amp.
Goatdog is offline   Reply With Quote
Old 06-12-2019, 07:14 PM   #4
A32Deuce's Avatar
Mine had a fuse behind it. Did not see it till I pulled it to replace the dector.
A32Deuce is offline   Reply With Quote
Old 06-13-2019, 12:41 PM   #5
Telstar's Avatar
My Cardinal has a online fuse located behind the unit.
Gary and Donna
2005 Cardinal 33TS-LX
Trail Air pin box
Center Point suspension
2018 Ram Laramie 3500 6'4" box 2WD
Demco AutoSlide 18k
Telstar is offline   Reply With Quote
Old 06-13-2019, 03:43 PM   #6
Not sure what RV you have, but on my Charleston it is a 3A fuse in the converter compartment
ckabrahamson is offline   Reply With Quote
fuse, gas
