11-29-2011, 02:29 PM
Got mtn bike?
I know that this is an old thread.
But after doing several searches, this is the only thread close to what I was searching for.
I thought my input of a current purchase might be of help to someone.
On my 2012 RockWood, I'm not to thrilled with the idea of cooking on the gas grill so close to the TT.
So I bought this 39" quick connect extension hose at Amazon.com. I would have preferred a longer hose, but it will work.
Amazon.com: Camco 57280 39" RV Quick-Connect to Quick-Connect LP Gas Hose: Automotive
11-29-2011, 02:54 PM
Having Fun Member
I guess if you wanted additional length you could purchase two of these, but then you're paying for extra fittings.
2011 Rockwood 8285 WS
2011 GMC 3500 HD 4X4, 6.0, 4.10, SRW
11-30-2011, 09:32 AM
Anacortesians
It was my understanding that you need to hook the T-piece upstream of the RV's own regulator then take the regulator off the grill and connect it on to the T-piece. Then you have only the pressure drop in the extension hose to wonder about.
I got a Weber Q-220 and will be setting it up for next season. I'd like to get about 15' away from the RV with the grill.
Weber sells a shorter extension to run the grill off a 20-lb bottle, but that means a run of rubber hose at bottle pressure rather than regulated pressure. I'm not sure I want to do that for 15 feet.
Frank and Eileen
1 Labrador - Bailey (M) now 8. RIP Cocoa 06 Sep 11.
02 Georgetown 325, F53 V10
12-13-2011, 11:06 AM
Chaney
any idea on finding coach to grill extension
I haven't been able to find a hose with a 1/4 quick connect on one end and the standard male grill connection on the other, can piece together if I could find longer hose that just had female nuts on both ends??
any help very appreciated!! Morace
12-15-2011, 12:37 AM
F and E.
If you take the regulator off of the BBQ you can hook the BBQ directly to the quick connect(without the BBQ regulator) on the rv as the rv regulator drops the tank pressure to the pressure needed for the BBQ.Just need to buy a hose to go from the BBQ to the quick connect.
12-15-2011, 09:26 AM
We cooked all season with our RVQ exactly where it's set up by the factory - attached to the bracket on the TT. Can't really understand why everyone is so squeamish about using it this way. Our TT didn't catch fire, or blow up, melt, get greasy, etc. The only thing we did do is switch the position of the small table and the RVQ; it was set up by the factory to be used to the left of the table; we switched it up and it is now to the right of the table. Necessitated getting a bit longer hose, which my DH took care of. Putting up with a much longer gas line and moving it to a table, would be, in my opinion, a hazard; very easy for someone to trip over the hose, etc. and send the entire hot grill flying.
2012 Rockwood 8293RKSS
2006 Dodge Ram 2500 5.9L Cummins Turbodiesel 4x4
2002 Dodge Durango 4.7L 4x4
Days camped 2011:61 (5/21 to 10/22) Days reserved 2012 (so far!!) 56 Days camped 2012: 9
12-15-2011, 04:52 PM
Having Fun Member
I too used the grill attached to the camper for about 10 weeks this year with no problems. However, we did have to occasionally close the camper doors to keep the awesome smell and smoke out.
12-15-2011, 08:02 PM
When we head out on our family/friends outings we take a larger BBQ to accommodate the extra people that we invite for both the weekend and daily.We place the BBQ close to the quick coupler so tripping over the hose is not an issue.It sounds like some of the RV'ers are looking at having a "better" BBQ which may not be able to be attached to the TT.
09grizzy1
| Thread Tools |
| Display Modes |
» Recent Threads |
» Online Users: 710 |
| 149 members and 561 guests |
| Alisa06, alpinemike, artnlisa, bagged123, BeagleIL, Bearcat55, bikendan, blaisrv, BlakeB, bo criswell, boubou, brady, brookside, Buffalohunter, Cafjackracing, camper1953, camping4us, Cascade Bob, cat1956, CCrane2299, cdbus, chof16, ChrisZazzara, ColoradoGreg, Cowracer, creed, Csbower, cstover, cyclepuck, DAISY BOYKIN, danielpburke, danred, dapersico, davidjb, depo, dfrauhiger, djorgensen3, dnaraG_1M, doc73, donn, doosterhouse, drobert, duchie, dunnnc, dustman_stx, emljr, Emptypockets, extremebike, f1100turbo, Falcon35, Fire Instructor, Flashg_123, Foneguy, fpdeod, gator14, gmw65, grhodes50, HemiCab, Hilgy, hokiecampers, hotrodj125, irish01, Itsthetwoofus, jamesroadking, Janet H, jar3316, jkinger, jrb988, Juan.Cortes, kegoneill, Kevin-and-Julie, KKapa, klucas, KyDan, lbhird, ldmcmahan, ldprice47, LFugate, lmcleister, lochsa, Loopyhamil, Mark S, mbrwr, mhartzel, michaelpike, Michigan, Mickey1, mike2tall, milw156, Mnflyboy, nailit, Nursx2, PAMROBERTNC, pandkm, papap, PaulK, pgordemer, phone man, photog, Piston, pmsherman, popbreed, Ptmaazx6, punkaccountant, pwadini, RattVader, redfox217, rgmiller32, rick51, RJHuser, rkswyo, rob2112, Rogue69, rotorhead1250, SabreSam, Sahgie, sail2liv, Sailfish Bret, scout800, scroses40, SDENN4281, shane1234, shrimper, silly2635, SimchaSabre, Snowsail, stevem4134, T.Kott, TacBear, tbritt, Tee, Test Account, texashatter, Timex, Titleguy, tlc, tmmar, trailraider, travyp, Triguy, tshayn, vlite2011, wagon52, Warrior, washdweller, wayne anthony, william.migues, wnytaxman, Zadnichek |
| Most users ever online was 944, 03-04-2012 at 01:27 PM. |
