Old 06-30-2012, 07:30 PM   #1
punkaccountant's Avatar
Lubricate Scissor Jacks
What do you all use to lubricate your scissor jacks? Grease, WD-40? Thanks for your help!
punkaccountant is offline   Reply With Quote
Old 06-30-2012, 08:09 PM   #2
campfirefun's Avatar
I use the same Teflon I use on the slide gears
campfirefun is offline   Reply With Quote
Old 06-30-2012, 09:42 PM   #3
Rebel702's Avatar
X2 and on the steps.
Rockwood Windjammer 3002W (11/10/2011)
2011 Sierra Denali HD - Duramax/Allison
EQ-4, 14,000/1,400
2006 Yukon Denali
Rebel702 is offline   Reply With Quote
Old 06-30-2012, 10:04 PM   #4
caper's Avatar
WD-40 is not a lubricant.
Terry and Janet
2008 3001W Windjammer
2007 Ford F150
Old 06-30-2012, 10:22 PM   #5
amxpress's Avatar
This is from the WD-40 website:
WD-40 Multi-Use Product fulfills five basic functions:
1. LUBRICATES: The product's lubricating ingredients are widely dispersed and tenaciously held to all moving parts
2. PENETRATES: WD-40 Multi-Use Product loosens rust-to-metal bonds and frees stuck, frozen or rusted metal parts.
3. PROTECTS: The product protects metal surfaces with corrosion-resistant ingredients to shield against moisture and other corrosive elements.
4. REMOVES: WD-40 Multi-Use Product gets under dirt, grime and grease. Use it to remove gunk from tools, equipment and vehicles. WD-40 Multi-Use Product in liquid form (e.g., gallon) also dissolves adhesives, allowing easy removal of excess bonding material.
5. DISPLACES MOISTURE: Because it displaces moisture, WD-40 Multi-Use Product quickly dries out electrical systems to eliminate moisture-induced short circuits.
I have used WD-40 on my manual sissors jack, as well as the dry lube spray used on my slide rack gear.
2013 Palomino Columbus 320RS
2007 Dodge RAM 2500 6.7 Cummins
Reese 15K manual slider
Prodigy
M.I.L. in Florida for good!!
amxpress is offline   Reply With Quote
Old 06-30-2012, 10:53 PM   #6
KRS
KRS's Avatar
I spray wd-40 on them for each use. Not oily enough to cause dirt buildup, but enough for one-time lubrication
2004 Forest River Wildcat 29BHS
15.0 BTU ducted roof air
Tow vehicle: 2006 Dodge 3500 cummins turbo auto
Cummins exhaust brake
Air bags
KRS is offline   Reply With Quote
Old 07-01-2012, 01:43 AM   #7
Too old to be too smart
SpringerPop's Avatar
There are FAR better lubricants than WD, especially for this application. Far....
It has its place, but lubricating jackscrews isn't a good one.
Pop
2005 Terry 250RKS, perfect for the two of us and the pups.
It recently replaced our Flagstaff 21FB (which we still have)
2000 F-350 7.3L CC/LB 4WD Lariat 3.73's
SpringerPop is offline   Reply With Quote
Old 07-01-2012, 02:39 AM   #8
ken0042's Avatar
I suppose the more accurate wording would be WD-40 is not a permanant lubricant. Meaning it will lubricate for a short period of time. However it will remove any grease or other lubricant, and then evaporate itself.
So if you need to remove something that is rusty, WD-40 makes a great lubricant. However never use it for something permanant.
Wolf Pup T16P owner
"The trouble with quotes on the Internet is that it is nearly impossible to discern if they are genuine." - Abraham Lincoln
ken0042 is offline   Reply With Quote
Old 07-01-2012, 02:52 AM   #9
You could also use diesel "oil", but the long-term results would be about on-par with WD.
Pop
Old 07-01-2012, 06:45 AM   #10
lindy's Avatar
For as slow as the jack screw turns and as seldom as it is actually used I see no great neat to lube it all the time. It comes from the factory with a lub on it and that's all I use. I've not added any lube in the five years I owned my last trl. If I did lube it'd be a sylicone spray.
2012 Winnebago "Journey To Insanity" 40U
2008 Dakota Sport 4x4
2004 Subaru Baja - DW's
2006 Honda Shadow Aero - TOAD for now.
F.R.O.G. member
lindy is offline   Reply With Quote
