Old 09-26-2010, 10:18 AM   #1
tmmar's Avatar
Magnum Inverter/Charger
I have a 200w Magnum Inverter/Charger in my coach. The documentation says that it has a 5 stage charging capacity -Bulk, Absorb, Float, Equalize, and Battery Saver. Does anyone know what each stage does? Also, is one of the stages a 'desulpherizing' (sp?) function?
Tom and Margaret
2014 Berkshire 390bh-60
tmmar is online now   Reply With Quote
Old 09-26-2010, 10:45 AM   #2
NWJeeper's Avatar
Battery saver is the "desulfating" mode.
Equalize is an "overcharging" if you will that provides 14.4 volts to the bank at a very low amperage rate. It is required to maintain the batteries correctly and insure that you actually get to 100% charge.
Float is just that, a steady voltage at very low or no amperage
Absorb I belive is after the bank has reched 90% charge level it will taper back the charge amperage to a "trickle" and up the voltage to around 13.6 volts
Bulk is for when the battery bank is below 90% charge, you will get 13.2 volts in most cases and a high amperage (usually 15 to 25amps give or take) to quick charge the bank up to the 90% level.
Ed & Wendy
www.nwjeepn.com
Old 09-27-2010, 08:28 AM   #3
tmmar's Avatar
Jeeper,
Thanks for the explanation. Very helpful!!!
Tom and Margaret
