11-10-2011, 07:09 AM
#21
I have the same setup on my Wolf Pack slider as does TexasBBQ and I have the same gap between the nuts on the ram. The slider never has jerked when sliding in and out. I do grease the gear tracks and the guides underneath where the tube steel slides into when closing the slider.
Ed & Laureen
2005 F-250 4X4 SD 6.0 Powerstroke
2009 Cherokee Wolf Pack 285wp (toy hauler version)
11-10-2011, 07:20 AM
#22
the upstairs is better supported on the 2004 than the 2002. ie it should give less.
tires are important. the tire can damage the side and under a trailer if allowed to run till it comes apart (i did that because i didn't know i had a flat).
i can't think of anything else to tell u to watch for. the cracks are the only major thing to go wrong on mine and they didn't show up till this year. with that, i will say, enjoy it.
if u don't have cracks yet, i would suggest going ahead and putting the cross brace in. there is a suggest frame repair on lippert's web site.
MOR/ryde Trailer Crossmembers - PPL Motor Homes
has an adjustable one.
the picture is the way the factory recommends it. one would go between each spring support.
(the picture below was borrowed w/o permission from another club member)
11-10-2011, 12:34 PM
#23
Dallas Texas
I think that's a good proactive countermeasure. I wonder how many have actually cracked based on the population. I've not heard bout this on other trailers - looks like a design issue. Has anyone ever called Forest River on it?
11-10-2011, 09:25 PM
#24
i don't know what the percentage is. both forest river and lippert are aware of it.
lippert says it is from backing too sharp among other things. lippert has a bulletin on it but no recall. this is a link to the repair recommendation.
http://lci1.com/images/Flyers/LIPShe...e-location.pdf
this is a link for ur slide outs. may have to work back to the list to find urs. http://lci1.com/images/Flyers/Owners...ideout-web.pdf
11-11-2011, 08:43 PM
#25
Dallas Texas
Thanks for the info. What is the relationship between Forest River and Lippert?
11-11-2011, 10:58 PM
#26
Lou Amadio
Originally Posted by donn
Sorry, you NEVER want to use any sort of grease. Use only dry lube. If anything else has ever been used on the slide mechanism that could be your problem. Grease of any sort will attract and trap dirt/sand/crud of all sorts causing no end of problems.
Times several.
Never use grease of any type on the slide mechanisms.
Spray Dry Lube only.
Lou and Laura Amadio and Bella the German Short Hair Pointer
2010 Flagstaff 8526RLWS 5th Wheel Pullrite Hitch
(2009: 28) (2010: 74) (2011: 93) (2012: 4)
11-11-2011, 11:01 PM
#27
Lou Amadio
Lippert and Dexter are typical frame and slide mechanism manufacturers used by FR and other RV builders. The RV builders mostly buy standard components and assemble them into campers and motor homes.
www.lci1.com
| Thread Tools |
| Display Modes |
» Recent Threads |
» Online Users: 705 |
| 149 members and 556 guests |
| 11XLITE28BH, 64c10, alpinemike, artnlisa, bagged123, BeagleIL, bikendan, blaisrv, BlakeB, bo criswell, boubou, brady, brookside, Buffalohunter, Cafjackracing, camper1953, camping4us, Cascade Bob, CCrane2299, cdbus, chof16, ChrisZazzara, Cowracer, creed, Csbower, cstover, cyclepuck, DAISY BOYKIN, danielpburke, dapersico, davidjb, depo, dfrauhiger, djorgensen3, dnaraG_1M, doc73, donn, doosterhouse, drobert, duchie, dunnnc, dustman_stx, emljr, Emptypockets, extremebike, f1100turbo, Falcon35, Fire Instructor, Flashg_123, Foneguy, fpdeod, gator14, gmw65, grhodes50, HemiCab, Hilgy, hokiecampers, hotrodj125, irish01, Itsthetwoofus, Janet H, jar3316, jkinger, jobren4, jrb988, Juan.Cortes, kegoneill, Kevin-and-Julie, KKapa, klucas, KyDan, lbhird, ldmcmahan, ldprice47, LFugate, lmcleister, lochsa, Loopyhamil, Mark S, mbfree66, mbrwr, mhartzel, michaelpike, Michigan, Mickey1, mike2tall, milw156, Mnflyboy, nailit, NINA, Nursx2, PAMROBERTNC, pandkm, papap, PaulK, pgordemer, phone man, photog, Piston, Playtime III, pmsherman, popbreed, Ptmaazx6, punkaccountant, pwadini, RattVader, redfox217, rgmiller32, rick51, RJHuser, rkswyo, rob2112, Rogue69, rotorhead1250, SabreSam, Sahgie, sail2liv, Sailfish Bret, scout800, scroses40, SDENN4281, shane1234, shavard, shrimper, silly2635, SimchaSabre, Snowsail, stevem4134, T.Kott, TacBear, tbritt, Tee, Test Account, texashatter, Timex, Titleguy, tmmar, trailraider, travyp, Triguy, tshayn, vlite2011, wagon52, Warrior, washdweller, wayne anthony, william.migues, wnytaxman, Zadnichek |
| Most users ever online was 944, 03-04-2012 at 01:27 PM. |
