Originally Posted by NMWildcat
Just to clarify for other folks; the newer models have these mini breakers, most of the older models (mine is 2012) do not.
X'2 Mine is only I think is an 80 amp breaker with a red button on it, that is not the reset an little arm will pop up and you will need to push it back down to get power back to the pump. Also thanks for the link, I copied it to my bookmarks, a lot of info in that link...
And to the OP, I understand your concern, I had the same. To get past that I learned the system while in my driveway not at a CG. Work the system, if you get stuck like I did you can call LCI, not all LCI systems are the same. If you call LCI you will need to take a picture of your controls and text it to the rep. from that point they can help you out a lot faster and easier. I know I never would have found my breaker to the pump without them seeing the control and telling me what to look for..Hope that helps...
