Old 09-30-2016, 11:38 AM   #1
Manually retract Lippert 6 point auto level
Hello All,
We are planning a 6,200 mile trip from NY out to Montana and Utah (and) all the states in between.
It's phase 6 of our quest to cover all 50 states as a family. We are up to 33!
2 nagging concerns of mine are what to do if the autolevel system legs won't retract, and if the slides won't come in. Thoughts of being stranded really bother me....
Does anybody have a direct link as to how to manually override the lippert hydraulic legs, and slides?
Thanks!
hkench is offline   Reply With Quote
Old 09-30-2016, 11:53 AM   #2
A simple internet search found this:
http://www.lci1.com/assets/content/s...ers-Manual.pdf
Jim & Anne
2017 CC 38EL
JAClend is offline   Reply With Quote
Old 09-30-2016, 12:05 PM   #3
Is this a double post?
http://www.forestriverforums.com/for...ml#post1330314
Days Camped '19=118 '20=116 '21=123 '22=134 '23=118 '24=90
Old 09-30-2016, 12:05 PM   #4
NMWildcat's Avatar
Below is the best video site I have found for products used in FR (mostly Lippert). The link to 'Lippert Slide-Outs - Manually Override Hydraulic Slide-Outs' gives a pretty good description of how to do this for SLIDES AND JACKS (second column about 3/4 down). Of course the system shown doesn't look exactly like mine but all the parts are the same (just different locations). Hope this helps! I worried about that also, but after 5 years we haven't had one problem with the hydraulic system (slides or jacks).
Videos by Forest River RV
Hope you never have to use the manual override!!
Scott and Liz - Southern NM
2007 Chevy 2500HD Duramax
NMWildcat is online now   Reply With Quote
Old 09-30-2016, 12:45 PM   #5
Getting slide in.
By far the best video out there! I've watched most of them.
Jump ahead to 1:54 for manual retraction of Schwintek slide!
Old 09-30-2016, 12:48 PM   #6
It looks that way...weird.
Both posted at Today, 12:38 PM
Old 09-30-2016, 01:09 PM   #7
Dorothy and the Tinman
Check first
Before going thru manual over-ride, check the breakers on what I call the terminal blocks. The cables from the hydraulic pump connect to them. Along the side are little black buttons. (Have to feel for them as they are very tiny.) If one is tripped it will knock out the system.
Ask how I know. ..lol
Joan is offline   Reply With Quote
Old 10-01-2016, 02:17 AM   #8
NMWildcat's Avatar
Just to clarify for other folks; the newer models have these mini breakers, most of the older models (mine is 2012) do not.
Old 10-01-2016, 04:45 AM   #9
Witch Doctor's Avatar
X'2 Mine is only I think is an 80 amp breaker with a red button on it, that is not the reset an little arm will pop up and you will need to push it back down to get power back to the pump. Also thanks for the link, I copied it to my bookmarks, a lot of info in that link... And to the OP, I understand your concern, I had the same. To get past that I learned the system while in my driveway not at a CG. Work the system, if you get stuck like I did you can call LCI, not all LCI systems are the same. If you call LCI you will need to take a picture of your controls and text it to the rep. from that point they can help you out a lot faster and easier. I know I never would have found my breaker to the pump without them seeing the control and telling me what to look for..Hope that helps...
Coachmen M/H
Concord
2018 / 300 DSC
Old 10-04-2016, 12:07 PM   #10
Stormrider151's Avatar
FYI. LCI has an app called "my LCI" that has tons of information about their systems on it. From parts lists to trouble shooting almost all of their products. It's my go to source when I have an issue.
Retired Fire Dept Battalion Chief
2016 Ever-Lite 232RBS
2012 F150 FX4 W/Max tow & Ecoboost (Best tv ever)
2018 F250 Lariat (ok but I miss my F150)
Getting old ain't for wimps!!!
Stormrider151 is offline   Reply With Quote
Old 10-04-2016, 01:07 PM   #11
Sormrider, Thank you very much for that information.....
Coachmen M/H
Concord
2018 / 300 DSC
manual
