Old 12-20-2015, 06:19 PM   #11
Left Coast
Clearance lightsClick image for larger version
Sent from my XT1080 using Tapatalk
Old 12-20-2015, 06:33 PM   #12
Left Coast
Glenn, the taillights are on same circuit.....
Old 12-20-2015, 06:58 PM   #13
Originally Posted by youroo View Post
Your a Hard man to Find! Yes get a resetable breaker or you will Never keep up changing fuses while trying to locate your short! I would start by checking ALL the places You and Your Little Buddy (Drilled/Changed/Installed all your Mods)! You Only have until March to find the short! Youroo!!
Don't point fingers at me, I never drilled any holes except for the awning poles. Screws for his basement slide out were not long enough to go thru the 1/2" plywood floor. He's pulled that trailer 1000's of miles and now all of a sudden it's blowing fuses? Sounds more like a truck problem. Plug a 20 amp fuse into the trailer umbilical cord to terminals 3 & 4 (the ones on each side of the tang) and if it blows, it's the trailer wiring, if it doesn't blow, it's the Found On Road Dead.
Old 12-20-2015, 07:01 PM   #14
Left Coast
There you are! hope everything is fine...
Old 12-21-2015, 04:26 AM   #15
arpipeliner's Avatar
Putting a fuse in the 7 pin will test it at static but you said while towing. I would have another vehicle with communications to you and pull the camper around CG or private road or parking lot. They might see a light flicker before blowing fuse. Saying the 5th might be in a flex position and pinch a wire. Start looking at the simplest things and then in deeper.
arpipeliner is offline   Reply With Quote
Old 12-21-2015, 04:29 AM   #16
Another simple test especially for boat trailer. Plug in and hit the brake and turn signals. Have had a bad housing before.
Old 12-21-2015, 05:21 AM   #17
Witch Doctor's Avatar
Originally Posted by B and B View Post
They stuffed insulation in your cap because it was caving in correct? Wondering if they shorted a connection there.
Brian, I have had this problem from day one, FR threw there hands up said they would have to remove my whole roof. They can't find it because it will only blow when driving, might be 2 miles or could be 50 miles before it blows. It is not the truck I can rule that out. I'll start with the plug and work backwards. I will keep folks informed on my progress, but got to fix that water pump first. Todays project. Maybe I need a New Wild Cat....
Coachmen M/H
Concord
2018 / 300 DSC
Witch Doctor is online now   Reply With Quote
Old 12-21-2015, 05:43 AM   #18
Glenn just be glad it is NOT your (Brake/Tail lights),that will put you OUT of RVing! Had that happen in VT/NH area. We were (Holed Up) until a SUPER mobile Teck found the Wires that (Only While Moving) would blow the Truck Fuse! It was a stroke of Luck that the Mobile Teck had worked for KZ and he knew right where to look inside the Nose area for the Wires that would rub and short out (1 mile or 50 miles)! I feal your Pain! Youroo!!
Old 12-21-2015, 11:57 AM   #19
Thanks Youroo, I don't drive at night, by then I'm to DRUNK, but when it rains they say your head lights have to on during the day. I don't know if they can pull me over for markers not being lit. Got the water pump working again. Took it apart and cleaned everything. s
Still finding cons't crap in the filter. Well it's 1:00 PM here and 85 degrees. Wind blowing a good 20 and gust to at least 30 mph. When the wind blows I have to thank Turbs.The trailer is rocking and rolling and it not what you think. But I'm the only one in the whole CG flying Old Glory, and my US ARMY FLAG, plus my FROG Flag. I'm in another world down here.. ..... Very strange CG but it has a bar (Tiki Hut) I'll post pictures. It's right behind my spot, I can crawl home.
Coachmen M/H
Concord
2018 / 300 DSC
Old 12-21-2015, 12:11 PM   #20
TURBS's Avatar
Glenn this is just to much of a hassle, just trade it to.
2015 Columbus 320RS
2008 2500HD Duramax
2015 nights camped "34"
