Old 12-21-2015, 04:55 PM   #31
mcnabbwr's Avatar
Originally Posted by bob caldwell View Post
I've seen a proximity volt/ ohm meter at Wallmart....might be worth a look...or, find a Snap On dealer
Hey Bob, if he doesn't have it fixed by May we could tear it apart at the rally. Might be interesting to see what we could find.
Bill & Pam
2014 Trilogy 3650RE
2015 F350 PSD
mcnabbwr is offline   Reply With Quote
Old 12-21-2015, 04:59 PM   #32
Left Coast
30 amp fuse would find it! Glenn, try 1 fuse up from what it calls for....had to do that when I added after-market tow mirrors
Old 12-22-2015, 03:07 AM   #33
Witch Doctor's Avatar
The dealer hooked up some meter that they plugged my cord into, I forgot now it's been almost 4 years but they pull only like 4 amps and it's a 20 amp fuse now. Today I'm pulling apart the junction box I have a DC amp probe and see what they are pulling, think I will ohm the plug end and find the right color wire and test that. Pulled all the markers yesterday no signs of water anywhere and they all work when jumper out. I'm going to google that short meter and see what people are talking about. I have a 110v tracer but I don't think that will pick-up 12V. At least the water pump is fixed now.
Coachmen M/H
Concord
2018 / 300 DSC
Old 12-22-2015, 04:47 AM   #34
Glenn,are you at your Winter location now? Do you have to Move every 2 weeks? Are you still walking 6 miles a Day? Power Lifting around 300#? Buying Stock in a Fuse Co.? Hope you find the short! PS, Don't Swim your Normal 5 miles every day if there is Red Tide! Don't Drink the Water (Safe there) and Don't eat the Fish you catch Every Day! Youroo!! Army Strong!
Old 12-22-2015, 06:29 AM   #35
bubbles's Avatar
Yep, put in a big enough fuse and that pesky short would definitely be eliminated.
Old 12-22-2015, 07:11 AM   #36
B and B's Avatar
Originally Posted by OldCoot View Post
Don't point fingers at me, I never drilled any holes except for the awning poles. Screws for his basement slide out were not long enough to go thru the 1/2" plywood floor. He's pulled that trailer 1000's of miles and now all of a sudden it's blowing fuses? Sounds more like a truck problem. Plug a 20 amp fuse into the trailer umbilical cord to terminals 3 & 4 (the ones on each side of the tang) and if it blows, it's the trailer wiring, if it doesn't blow, it's the Found On Road Dead.
He bought a new truck so by process of elimination the Trailer is at fault. I would take each light out and check all connections myself. My Money is still on the cap area, they did work there getting the bumps out!
2017 Heartland Bighorn 3575 Elite with Reese Sidewinder
2016 Ford F 350 SD PS 6.7 SRW Crew Pucks and Reese 18 K Elite
2013 Rockwood 8289WS 2012 Rockwood 2703 SS TT 2007 Golden Falcon 38FLA PM 1983 Corsair 21RB
2015 Ford F250 PS '13 F150 3.5 Eco '09 F150 5.4 l 1987 Merc Grand Marq 1982 Ford E250 CW
Old 12-22-2015, 07:13 AM   #37
B and B's Avatar
Well in a different land at a different time we used to trace blown Triax cable plugging it into 120 VAC at 20 amps, usually smoke or a hole blown in the cable would show up quickly.
Old 12-22-2015, 09:05 AM   #38
Left Coast
Ground a test light into the pig-tail ground , test with light into other sockets (taillights), see if the light lights, then do the same with an ohm meter
Old 12-22-2015, 09:06 AM   #39
Georgia Frog Rally 2018
aceinspp's Avatar
X 2 be a good game. Later RJD
2018 Dodge Ram 2500 6.4 3:73 gearing.
Days camped in 2016 58
Days camped 2017 62
Days camped 2018 18
aceinspp is online now   Reply With Quote
Old 12-22-2015, 09:14 AM   #40
Left Coast
When did this start?
