12-21-2015, 01:12 PM
#21
Here is a tool that could help.
GearWrench Short Circuit Detector - 2524
Locates short circuits in 6 and 12V systems right through upholstery, body panels and metal door posts
Connect tester across burned out fuse. Move meter along wire routing
Meter needle will oscillate until short is found
ABTM part number: KDT 2524
Note: Returns are allowed for diagnostic equipment as long as the item has not been used and the package is in salable condition.
Shipping rate only applies within the Continental United States. All other customers will be contacted with shipping rates.
12-21-2015, 01:14 PM
#22
Left Coast
I'd fix it fer 'ya, but your there and I'm here........
12-21-2015, 01:17 PM
#23
Left Coast
Have a similar type tool, but there again, it's home.....did the add say anything about how close the meter needs to be to the wiring?
12-21-2015, 01:18 PM
#24
12-21-2015, 04:03 PM
#25
Originally Posted by TURBS
Glenn this is just to much of a hassle, just trade it to.
2015 Columbus 320RS
2008 2500HD Duramax
2015 nights camped "34"
Turbs don't know if I can afford one and if my nose will go high enough in the air my friend....
Coachmen M/H
Concord
2018 / 300 DSC
12-21-2015, 04:04 PM
#26
Where do you find this magical device?..... Thanks
Coachmen M/H
Concord
2018 / 300 DSC
#27
Marker lights keep blowing fuse
Well with all those awning brackets that you had to peddle this year I'd think with your stipend you'd have a good down payment!
2015 Columbus 320RS
2008 2500HD Duramax
12-21-2015, 05:07 PM
#28
Left Coast
I've seen a proximity volt/ ohm meter at Wallmart....might be worth a look...or, find a Snap On dealer
12-21-2015, 05:42 PM
#29
Glenn Google power probe, I have one and love it!
2015 Columbus 320RS
2008 2500HD Duramax
12-21-2015, 05:44 PM
#30
Ect2000
2015 Columbus 320RS
2008 2500HD Duramax
12-21-2015, 05:55 PM
#31
Hey Bob, if he doesn't have it fixed by May we could tear it apart at the rally. Might be interesting to see what we could find.
Bill & Pam
2014 Trilogy 3650RE
2015 F350 PSD
12-21-2015, 05:59 PM
#32
Left Coast
30 amp fuse would find it! Glenn, try 1 fuse up from what it calls for....had to do that when I added after-market tow mirrors
12-22-2015, 04:07 AM
#33
The dealer hooked up some meter that they plugged my cord into, I forgot now it's been almost 4 years but they pull only like 4 amps and it's a 20 amp fuse now. Today I'm pulling apart the junction box I have a DC amp probe and see what they are pulling, think I will ohm the plug end and find the right color wire and test that. Pulled all the markers yesterday no signs of water anywhere and they all work when jumper out. I'm going to google that short meter and see what people are talking about. I have a 110v tracer but I don't think that will pick-up 12V. At least the water pump is fixed now.
Coachmen M/H
Concord
2018 / 300 DSC
12-22-2015, 05:47 AM
#34
Glenn,are you at your Winter location now? Do you have to Move every 2 weeks? Are you still walking 6 miles a Day? Power Lifting around 300#? Buying Stock in a Fuse Co.? Hope you find the short! PS, Don't Swim your Normal 5 miles every day if there is Red Tide! Don't Drink the Water (Safe there) and Don't eat the Fish you catch Every Day! Youroo!! Army Strong!
12-22-2015, 07:29 AM
#35
Yep, put in a big enough fuse and that pesky short would definitely be eliminated.
12-22-2015, 08:11 AM
#36
Originally Posted by OldCoot
Don't point fingers at me, I never drilled any holes except for the awning poles. Screws for his basement slide out were not long enough to go thru the 1/2" plywood floor. He's pulled that trailer 1000's of miles and now all of a sudden it's blowing fuses? Sounds more like a truck problem. Plug a 20 amp fuse into the trailer umbilical cord to terminals 3 & 4 (the ones on each side of the tang) and if it blows, it's the trailer wiring, if it doesn't blow, it's the Found On Road Dead.
He bought a new truck so by process of elimination the Trailer is at fault. I would take each light out and check all connections myself. My Money is still on the cap area, they did work there getting the bumps out!
B and B
12-22-2015, 08:13 AM
#37
Well in a different land at a different time we used to trace blown Triax cable plugging it into 120 VAC at 20 amps, usually smoke or a hole blown in the cable would show up quickly.
B and B
12-22-2015, 10:05 AM
#38
Left Coast
Ground a test light into the pig-tail ground , test with light into other sockets (taillights), see if the light lights, then do the same with an ohm meter
12-22-2015, 10:06 AM
#39
Georgia Rally Coordinator
X 2 be a good game. Later RJD
Traded 2015 30WRLIKS V-Lite
Days camped 2019 62
12-22-2015, 10:14 AM
#40
Left Coast
When did this start?
