Old 12-20-2015, 03:05 AM   #1
Witch Doctor's Avatar
Marker lights keep blowing fuse
My marker lights keep blowing the 20 amp fuse towing with my new to me 2007 f250 6.0. Same problem with my old 2004, so FR was wrong it is not my truck, any ideas?
Rockwood #8289 WS 2012
F250 6.0 / Husky 16k
With 4 point leveling system
Old 12-20-2015, 08:29 AM   #2
mcnabbwr's Avatar
Is it the marker lights on the truck or FW that go out? Place a fuse directly into the trailer plug, it may help in determining which area the problems in. If the lights on the FW stay on and doesn't take out that fuse the issue is the truck.
Bill & Pam
2014 Trilogy 3650RE
2015 F350 PSD
mcnabbwr is offline   Reply With Quote
Old 12-20-2015, 09:25 AM   #3
Left Coast
They make re-setable blade fuses.......school buses use 'em......like a mini gfi
Old 12-20-2015, 10:10 AM   #4
Your a Hard man to Find! Yes get a resetable breaker or you will Never keep up changing fuses while trying to locate your short! I would start by checking ALL the places You and Your Little Buddy (Drilled/Changed/Installed all your Mods)! You Only have until March to find the short! Youroo!!
Old 12-20-2015, 11:29 AM   #5
I will E mail Glenn his post location! Youroo!!
Old 12-20-2015, 02:20 PM   #6
Good chance a screw punctured a wire. You will have to trace wires and check each light. Dealer may have a pulser box to find the short.
Harkerr is offline   Reply With Quote
Old 12-20-2015, 05:28 PM   #7
B and B's Avatar
Glenn bought a new truck and still has the same problem. I guess that clears Ford and the truck aspect of the issue.
2017 Heartland Bighorn 3575 Elite with Reese Sidewinder
2016 Ford F 350 SD PS 6.7 SRW Crew Pucks and Reese 18 K Elite
2013 Rockwood 8289WS 2012 Rockwood 2703 SS TT 2007 Golden Falcon 38FLA PM 1983 Corsair 21RB
2015 Ford F250 PS '13 F150 3.5 Eco '09 F150 5.4 l 1987 Merc Grand Marq 1982 Ford E250 CW
Old 12-20-2015, 05:29 PM   #8
B and B's Avatar
They stuffed insulation in your cap because it was caving in correct? Wondering if they shorted a connection there.
Old 12-20-2015, 05:36 PM   #9
Left Coast
First place I'd look would be the trailer pig-tail plug, then work into trailer from there.
Old 12-20-2015, 06:16 PM   #10
DAISY BOYKIN's Avatar
Clearance lights
I told Glenn to check his rear clearance lights across the top of his Fifth Wheel in the rear for water. I had the same problem, discovered the rear top clearance lights were full of water.
Drilled a small hole in the bottom of the red lens to let the water drain out. Also caulked the top of the red lens to keep the water out.
Sid, Lois & HRH MISSY Terrible 2s SHIH TZU
2011 ROCKWOOD 8285 WS
2014 F-250 KING RANCH PS/SD/6R140/BFT
DAYS CAMPED 2018 21 DAYS
DAISY BOYKIN is offline   Reply With Quote
