Originally Posted by wanderer44
I have a 2019 Dynamax Isata 3 24 fw motorhome powered by Mercedes. When I start it in cold weather, the glow plug indicator light only comes on for about a second or two. Having a Mercedes before, I am sure that it needs to stay on longer to do much good. We are in the lower 20's now and worried that when it gets real cold it will not start.
Do you have any experience to share???? Thanks Leonard
I don't own a Mercedes, but have owned a number of diesel's. They are all now computer controlled, and will only stay on to get the temp up to what is needed. I have seen a flash, to 6-7 seconds. If it wasn't working correctly, it will throw a code. The computer checks the plugs every time you start the engine, even when they are not needed.
Your newer one may have "hotter" plugs then the old one, or the cylinder displacement is such that it may not take as long to heat up.
