Old 05-28-2008, 01:09 PM   #11
Rockinwood's Avatar
Not working, like shutting off?
2007 Rockwood 8317ss Reese Dual cam sway, 2002 Ford Excursion XLT V10,Prodigy Brake controller
Married DW 03/15/97 3 kids
Rockinwood is offline   Reply With Quote
Old 05-28-2008, 07:52 PM   #12
spepi's Avatar
yep...no beeps from the buttons either...almost like it is over heated...
DW, 2 Teen's, 2 Dogs
2006 Chevy Suburban
3.42 Gears
Prodigy Brake Control
Reese 800lb Weight Dist Bars
Dual Cam Sway Control
2008 Rockwood 2701ss
Mansfield, MA
spepi is offline   Reply With Quote
Old 05-28-2008, 11:05 PM   #13
Rockinwood's Avatar
iis it only doing that with corn on the cob, or all, I know there is a cavity thermal fuse, that will open if it gets to hot.
Old 05-29-2008, 05:40 AM   #14
spepi's Avatar
anything we cook for more than 10 min with water added into the recipe...like pasta....heat up so there is a lot of steam and moisture.....
2006 Chevy Suburban
3.42 Gears
Mansfield, MA
Old 05-29-2008, 08:39 AM   #15
Rockinwood's Avatar
I know it probably should not be so sensitive, but I think it is triggering either a thermal fuse or moisture control, what model and make is your micro?
Old 05-29-2008, 10:35 AM   #16
spepi's Avatar
Not sure off hand...i'll look later and post info...
2006 Chevy Suburban
3.42 Gears
Mansfield, MA
Old 05-29-2008, 10:59 AM   #17
The Jolly Mon
NDJollyMon's Avatar
Send a message via Yahoo to NDJollyMon
alright you thread hijackers!
...anyway...back to the original posters question...
When I plug the micro into a different outlet in the trailer...it works fine. Only trips on the outlet that was made for it.
Pete (Jolly Mon)
2018 Wildwood Grand Lodge 42 DLTS
-Seasonal Space, Northern MN.
-2017 Sylvan 8522 LZ LES/115 Merc/Sea Legs
NDJollyMon is offline   Reply With Quote
Old 05-29-2008, 11:51 AM   #18
KyDan's Avatar
I gave you my answer.
Bad or mis-wired GFI.
Old 05-29-2008, 01:25 PM   #19
Cyber Phrenologist
Radio's Avatar
Bad breaker or loose connection in the wiring. If it works someplace else that eliminates the m'wave.
As to the one that overheats, pull the cabinet work away and see if something is blocking ventilation. Some trash might have been left in there during construction and has shifted around to block a vent.
KU4OJ
Admin at www.openroadsradio.net, part of the Social Knowledge network.
"RVing and Amateur Radio served up on the same plate"
2008 (or is it 2009?) Rockwood 8280SS - 2007 F-150
Radio is offline   Reply With Quote
Old 05-29-2008, 02:07 PM   #20
Rockinwood's Avatar
I agree with Radio, check the vents, some on top, some are on bottom, Jolly, I agree with the other 2, now that your Micro is eliminated, wiring or ground?
breaker
