Old 05-27-2008, 10:49 PM   #1
The Jolly Mon
NDJollyMon's Avatar
Send a message via Yahoo to NDJollyMon
Micro tripping breaker..what up???
Ok, I need some electrical advice here....
I don't like to screw with it...cause I always get zapped!
ANYWAY...
This weekend...microwave worked just great. This morning...I go to use it, as soon as you hit START it trips the breaker off. It's plugged in up inside the cabinet...on a single outlet. The cord looks fine, clock and buttons work fine when breaker is reset...just trips when START is pushed. What the heck????
Pete (Jolly Mon)
2018 Wildwood Grand Lodge 42 DLTS
-Seasonal Space, Northern MN.
-2017 Sylvan 8522 LZ LES/115 Merc/Sea Legs
NDJollyMon is offline   Reply With Quote
Old 05-27-2008, 11:41 PM   #2
Rockinwood's Avatar
I think your problem may be the microwave, a shorted HV Cap can cause this, or shorted HV Magnetron, Just bring it into my shop in CA. I will give you a free Estimate LOL, .. Take your microwave out and take it in to a trustworthy shop, you may want to plug it into direct power, if you hear a loud hum or buzz unplug it, it may blow your breaker in the house.
Needed to add on more thing, one of the door switches could be bad also, ok one more, if you want to check you HV cap, it is the metal caseing unit, the wires go up to the Magnetron, unhook all wires, get a mutltimeter, check across the 2 terminals of the Capacitor to see if it is shorted, if it is, let me know the brand and model #, I will see if I can locate it for you. Also you will see the value on the capacitor itself.
2007 Rockwood 8317ss Reese Dual cam sway, 2002 Ford Excursion XLT V10,Prodigy Brake controller
Married DW 03/15/97 3 kids
Rockinwood is offline   Reply With Quote
Old 05-28-2008, 08:25 AM   #3
KyDan's Avatar
I agree.
Try it indoors and you'll likely get the same result.
I'm surprised it doesn't have an internal fuse.......
Oh, yeah-- You can probably buy a new MW for the price of fixing
that one unless you can DIY.
Good luck!
Old 05-28-2008, 10:17 AM   #4
bamasurveyor's Avatar
This past weekend I had a similar problem. When i tried to use our microwave, it would trip the GFI breaker. we had the A/C running, and a couple of fans outside. No TV or radio. Had to turn off everything to get the micro to run. any ideas?
John
Ted
bamasurveyor is offline   Reply With Quote
Old 05-28-2008, 10:23 AM   #5
KyDan's Avatar
Faulty or mis-wired GFI.
I gotta wonder why the microwave is on the GFI???
It should be on it's own circuit.
Old 05-28-2008, 10:34 AM   #6
AKA Bluebird
dimurrrw's Avatar
Send a message via Yahoo to dimurrrw
Bad breaker???
dimurrrw is offline   Reply With Quote
Old 05-28-2008, 10:48 AM   #7
Good point Kydan, The Converter/circuit board was replaced last year after a severe power serge fried the factory one. There maybe a crossed wire in there.
John
Ted
Old 05-28-2008, 11:05 AM   #8
Rockinwood's Avatar
I have to agree with you, this should not be wired to a GFI IMO, EX if you hook up a High power microwave to a power strip with a breaker, it will trip almost every time.
Old 05-28-2008, 12:09 PM   #9
Sounds like they are made by the Concertone people, too!!! Randy
Old 05-28-2008, 12:31 PM   #10
spepi's Avatar
the last few times I used my microwave to heat up some corn on the cob, it stopped working, and I had to wait 20 minutes for it to work again....now the breaker didnt trip....could it be overheating?
DW, 2 Teen's, 2 Dogs
2006 Chevy Suburban
3.42 Gears
Prodigy Brake Control
Reese 800lb Weight Dist Bars
Dual Cam Sway Control
2008 Rockwood 2701ss
Mansfield, MA
spepi is offline   Reply With Quote
breaker
