First thing you should do is get the area opened up to see where your problem is from the leakes you had, remove any wet material and any rotted wood, some times this just can be air dried however wood will warp and splinter after being wet and then dried. I would use a mixture of bleach and water to clean the area however if there is a fire restoration company near by they sell a spray for this type of problem,getting it dried out is the important thing here and insuring the leaks dont return, after you get every thing back in place and your flooring glued back down caulk around your tub and around the floor area,use 100% silicone and when using the chemicals use eye protection gloves and a mask make sure you get all the wet stuff out Hope this helps!
