Some of those mounting plates are only a few inches wide by a few inches tall. The 1/4" plywood is a a good size but if it were me, I'd make it wide enough to secure to a couple of internal studs on each side in the wall which you should be able to locate using a stud finder and/or the good old knock/press method where you feel for the firm vs. spongy section of wall board.
If you can identify a wall stud on each side and get a screw through the top and bottom of the plywood into each one, you will be solid and never have to worry about it coming loose. There is a lot of torque on those wall mounts, especially if you use an articulating arm that is not fully compressed against the wall and locked, bungeed flat.
2020 Chevrolet 2500 LTZ, 2019 Forest River Wolfpack 23Pack15, 2014 EZGO Golf Cart.
