07-31-2017, 11:51 AM
Mystery Switch
I just realized that the switch on the far right in the row of four does not control anything. The switch is wired but turning it on/off does nothing. I'm hoping someone can tell me what it controls on your camper. My guess would be a porch light or step light which I do not have.
07-31-2017, 01:36 PM
Kasual Kamper
Try turning all of your lights on and then flipping that switch. If one of them goes off, you've found the light that it controls. On my MicroLite 21DS, it's the light over the sink.
Current: 2013 Flagstaff MicroLite 21DS
Past: 2000 Fleetwood Mallard 19N
TV: 2013 Nissan Pathfinder SL 4x4
07-31-2017, 01:59 PM
Awning LED's or burned out porch scare light?
2015 F-250 FX4
07-31-2017, 04:49 PM
Mystery Switch
Tried that a earlier today...no luck.
07-31-2017, 04:51 PM
Mystery Switch
Nope Awning LEDs work if switch is on or off...and I do not have a porch light.
07-31-2017, 06:23 PM
Mine turns the lights on above my island. 27reis
07-31-2017, 08:02 PM
Step lights on mine
2016 Grey Wolf 26DBH
Ram 2500 5.7 Hemi 4WD
07-31-2017, 08:08 PM
Mystery Switch
Originally Posted by gconley
Step lights on mine
That makes sense but I have no step light...but I may have a junction box in the underbelly pre-wired for a light.
07-31-2017, 08:38 PM
Dallas Texas
How about a spot light on the other side? Or outside step light?
2004 Cardinal 33CKT
2006 Ford SDD F250 CC 4WD
08-01-2017, 08:51 AM
That could be it!
08-07-2017, 09:24 AM
Any update?
08-07-2017, 03:21 PM
Originally Posted by RV_Fan44
Any update?
No RV_Fann44 it's been raining almost everyday and I've been busy with mods inside the camper. I'll post something when I get a definite answer.
08-17-2017, 06:54 PM
I give up...have checked everything inside and out, even at night...the switch controls nothing
08-17-2017, 06:58 PM
You can always pull a battery lead and put a meter in between and measure the current with the switch on and off to see if there is a load attached to it.
08-20-2017, 04:55 PM
Mine operates the led light over the door. The remote on the wall will affect wether the panel switch will work or not. Maybe your's is the same?
08-21-2017, 02:54 AM
Thank you both, I'll check these ideas out next time I get out to the camper.
08-21-2017, 11:31 AM
Thank you 67vtx1800, The mystery is solved. Turning the switch on does nothing BUT, if you turn on the LED strip under the awning using the remote, you can then turn the LED strip off using the panel switch. Then you can turn the LED strip back on with the panel switch. Kinda like having a porch light.
08-22-2017, 08:37 AM
Glad you figured it out! NOW the question is.... will you use this switch?
08-22-2017, 03:31 PM
Yep now that the switch will turn the LED's on and off it will be my "porch light" from this point on.
08-28-2017, 08:25 PM
Happy camping!
I use mine all the time because I don't change colors or brightness often. However I swapped the position for the one to the left of it that runs the inside ceiling light because I can never find it in the dark! Makes more sense for it to be closer to the door as it is for an outside light and the other switch be the inner most as it operates a light on the inside...
Oz
