Old 03-12-2016, 04:37 PM   #1
Need Advice on Electric Awning Issue
So I thought the motor on my Solera awning had a flat spot on a gear or the motor windings. The awning will not extend without me manually extending the awning 6". After that it is fine except for a slight skip in the action.
Turns out the right extending arm is binding on the stationary arm when fully closed. Can I adjust this misalignment or do I need to "tweak" the arm a little? It appears that the motor is already cocked to the left which is the direction the arm needs to twist. Any ideas?Click image for larger version
ID:	101764Click image for larger version
Lee and Anne
2016 F250 2WD CC SB XLT 6.2 3.73 3,295 lb payload cap.
2014 Salem Hemisphere 282RK 8k lbs loaded, Equal-i-zer WDH, TST 507 TPMS
2017: 4 nights camped, 12 booked
Teamfour is offline   Reply With Quote
Old 03-12-2016, 04:51 PM   #2
Wobbles's Avatar
Google Solera parts. That head you are looking at may not be out of alignment.
I have not had trouble extending it. Mine gave me trouble retracting when it sounded like it was pulling the mounts out of the TT wall. I am still watching it as it only happened twice.
A look at the head mount:
Bob & Michelle
2016 Ford F-250 Lariat 4x4
2017 Flagstaff Super Lite 526RLWS
Wobbles is online now   Reply With Quote
Old 03-12-2016, 05:27 PM   #3
Left Coast
You can tweak it........After lots of highway miles, you might need to again...I've had to a few times...no big deal
Old 03-12-2016, 06:15 PM   #4
Excellent! I'll give it a try.
Lee and Anne
Old 03-13-2016, 02:38 PM   #5
Haven't had any problems like that on my Solera. I just have problems with the extension arms not staying in place- probably stripped bolt on one end. It came this way. Are you under warranty still?
mtnlvr is offline   Reply With Quote
Old 03-13-2016, 03:02 PM   #6
Witch Doctor's Avatar
X's 2 I have to tweak mine all the time. Alot of it has to do with the support you use....
Rockwood #8289 WS 2012
F250 6.0 / Husky 16k
With 4 point leveling system
Witch Doctor is online now   Reply With Quote
awning, electric
