Old 06-11-2017, 11:23 AM   #1
Need an accurate tire pressure gauge
Ok, I have two different air pressure gauges I use to check my tire pressure. They do not agree with each other. In fact, both seem to give different readings when compared to themselves. One I use (older fashioned one that has a plastic stem that pops out with the scale showing psi even will go to a specific psi then slowly keep extending. The other has a round gauge and a release pressure button. I am looking for gauge recommendations that have ACCURATE AND CONSISTENT psi measurements. Suggestions?
rogerkathy is offline   Reply With Quote
Old 06-11-2017, 11:35 AM   #2
I have a digital gauge from Groit's Garage that works well and adapted a bicycle pump hose with valve stem locking chuck. 90 deg and 45 deg valve stem extensions help as do self sealing metal valve stem caps that stay on the valve stem permanently.
landsail is offline   Reply With Quote
Old 06-15-2017, 08:15 PM   #3
https://smile.amazon.com/gp/aw/d/B00...mEL&ref=plSrch
This is the one I have and I find it is Accurate
jjjandj is offline   Reply With Quote
Old 06-15-2017, 08:43 PM   #4
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
Designed for duals, very accurate with 1 pound increments
Sunseeker24 is offline   Reply With Quote
Old 06-17-2017, 04:48 PM   #5
Ordered the following:
1x EliteProPlus™ Tire Pressure Gauge with Interchangeable Air Chucks - 160 PSI for $30.95 each (minus a $4 discount)
at
https://www.jacosuperiorproducts.com
Looks like it's made in America and has 100% warranty (I hope). Haven't had a chance to try it out yet but it seems really sturdy and seems to have brass fittings that are good quality. Will try it out this week.
Old 06-29-2017, 10:02 AM   #6
Tried the new tire gauge. Feels great, is sturdy, and well made. Appears to be accurate but haven't compared it with others (which could be inaccurate like my cheaper ones). Just need to go by faith. So far I would reccomend it.
Old 06-29-2017, 10:15 AM   #7
tmfaulksr's Avatar
i have this one also and works well
tf
the faulks & prince
2012 Nissan Titan CC
Roadmaster Active Suspension, Firestone Airbags
2015 Rockwood 8289WS Diamond Pkg
2015 Puma 253FBS (sold)
2013 BMW R1200GSW
tmfaulksr is offline   Reply With Quote
Old 06-29-2017, 02:00 PM   #8
CC75's Avatar
at
By chance I had ordered the same one thru Amazon. About the same price as yours with discount. I also have TST507 TPMS system on the trailer. I will compare the readings from both and report back.
CC75 is offline   Reply With Quote
Old 06-29-2017, 02:11 PM   #9
ben31's Avatar
To make sure it is accurate, take it to the local tire shop and they can test it. I had two supposedly "accurate" gauges which really weren't (off by up to 15%). I finally got one that is accurate, https://smile.amazon.com/dp/B00080QH...&pd_rd_w=J0WFD
I've had this tested at two tire stores and both say it is very accurate.
Ben and Doreen
Home Away From Home - 2017 PT Crusader 315RST
TV - 2016 Ram 3500 Laramie 4X4 6.7 Cummins Diesel
Never Enough Time Camping!!
ben31 is offline   Reply With Quote
Old 06-29-2017, 04:17 PM   #10
Unless the manufacturer is calibrating the gauge before it is shipped, accuracy is a crap shoot. You have no way of knowing without calibration - and calibration costs money. Comparing a gauge against another gauge is the poor man's calibration - you don't know if both gauges are out of wack. The more comparisons you do, the more likely you will know if your gauge is off or not.
Precision is something different. Precision is how small an increment you can measure, accuracy is how close the measurement is to the true value. Unfortunately, digital electronics can give a false sense of both precision and accuracy. When your gauge reads to a tenth of a PSI, you think you have both precision and accuracy. But that doesn't mean the sensor has either precision or accuracy - the processor could easily be making up that tenth of a PSI digit when the sensor can only measure to +/-2 PSI. Consumer voltmeters and multimeters commonly have this issue, too.
Fred W
pressure, tire
