Old 05-11-2014, 05:10 PM   #1
HookMeUp's Avatar
Need help locating an LP adapter
I have been having problems with my LP gas feeding from one side of the camper for about the last year. So yesterday I spent some time trouble shooting the problem and got it narrowed down to the auto change over valve. I pulled it off and started taking the fitting off of it and noticed that one of the 1/4" inverted flare adapters had something in it. Did some more testing and this was my actual problem. I have been trying to source a 1/4" inverted flare adapter with an internal check valve and can't find any. Any help locating one of these would greatly be appreciated.
2010 Wildcat 30LOFT
2011 RAM 3500 CCLB Cummins
HookMeUp is offline   Reply With Quote
Old 05-15-2014, 08:02 AM   #2
Old Enough to Know Better
gasman6674's Avatar
You wont find one. They are oem to the reulator
Replace your regulator.
Regards
Jim & Debbie England
Do you have Gas? 2015 F350 6.2L CCLB DRW 4.30 axle. 2012 Yellowstone Ridgeline 34RLT Fifth Wheel
gasman6674 is offline   Reply With Quote
cat
