05-27-2016, 09:41 PM
#21
Originally Posted by jmsokol
It's not shorted. If it was shorted then it would trip the circuit breaker. I believe there's was some water buildup around the switch which provided a current path through you to the wet ground you were standing on.
On a side note, most of the time a HW heater element with fail due to corrosion which allows water to contact the ni-chrome element. Then there will be around 1 amp of ground fault leakage current. There's a pretty simple current test can could be performed on RV's using a clamp meter, but no one to my knowledge has documented or performed this test. It's just something in my bag-of-tricks for troubleshooting electrical systems.
If you do turn on the electricity without any water, then the element can melt-down internally. Most of the time it should open-up, but there's a possibility it could short to the outer tube. But that won't be a hard short between two electric wires. In any case, if you have a properly ground-bonded RV, it can't possibly cause a hot-skin voltage condition.
Do you suppose replacing the socket that the water heater is plugged into with a ground fault interrupter has value? I'm not sure how this would behave if the ground to the trailer is open, but in the case of surface leakage from moisture on a switch to someone standing on wet ground it should trip just fine.
If this doesn't cause nuisance trips due to internal leakages in the water heater, it might save someone from a nasty shock.
05-27-2016, 10:01 PM
#22
I think better yet would be a redesign of the water heater. Remote the switch inside the trailer by control panel. Also shield the overtemp valve so water doesn't run down the whole water heater face.
B and B
05-27-2016, 10:33 PM
#23
Someone in a recent thread (last few days) had a pic where he put a fitting in the end of his valve and piece of PEX running down to the bottom of the heater, with an elbow at the bottom. This directed the water down and out.
2011 Traverse LT, 3.6L, FWD
05-27-2016, 10:40 PM
#24
Yeah. I really like the idea of a remote switch and pilot light.
In my trailer it's a little hard to run the wires from the heater to a decent location inside, so it'll be a while before I do this...
07-26-2020, 10:30 PM
#25
Simple current test
Could you tell me how to run the simple clamp test with my meter please? I am getting 1 amp shock when I remove my heater drain cap. I want to know if there is an element issue, or I’m just a great ground from the switch when wet. I suspect the element because there is a lot of corrosion on the threads, and when I bought it, the plug that was in it did not have the sacrificial anode.
07-27-2020, 08:40 AM
#26
If you have an Atwood/Dometic brand water heater, they do not have anode rods like Suburban brand does. They have aluminum tanks and thus no need for an anode.
Forest River uses both brands so we do not know without a pic perhaps.
You could still have a burned out electric heating element in either brand though
2011 Flagstaff 831 RLBSS
